Old 12-03-2017, 03:29 PM   #1
DBlum425
Drives: 2013 Subaru BRZ
Catch can fittings
Hey this is my first post, I got my BRZ a few months ago and have been working on it day and night. It had a turbo from the previous owner but I am re-doing everything. I am having a larger baffled catch can welded up and am switching the barbs on the block to AN fittings. However I cant seem to lock down what thread size the crank case vent and pcv valve are. I have searched far and wide and they seem to be 3/8 npt but I want to be sure before I order all the wrong fittings. Thanks!!!
DBlum425 is offline   Reply With Quote
Old 12-04-2017, 08:13 PM   #2
DBlum425
Anyone? I spoke to someone who said the pcv is 3/8 bspt confusing me even more. Pleeeeease help.
Old 12-17-2017, 11:36 AM   #3
DBlum425
anyone?
Old 12-17-2017, 08:54 PM   #4
Amputechture
Drives: 2014 BRZ
3/8 NPT threads into the block if you are deleting the PCV, I am absolutely 110% positive.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
Old 12-24-2017, 06:34 AM   #5
DBlum425
We are talking the crank case vent ( below the left side of the intake manifold if looking from the front of the car) and the pcv (under the ac compressor) correct? From my understanding I can vent both to atmo with a baffled catch can. Radium makes an AN adapter for the pcv which they claim to be bspt not npt.
Old 12-24-2017, 02:27 PM   #6
ls1ac
ls1ac's Avatar
If you want to check, go to Home Depot get a brass fitting. Try it out, heck you can even return it.
Zeitronix fittings? Tal DIY (Do-It-Yourself) Guides 2 07-17-2019 08:51 PM
Do Blowoff valves all have the same fittings? apelpapa Forced Induction 1 06-18-2016 03:00 PM
Replacing oil cooler line fittings? 1Cor10:23 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-17-2015 01:43 AM
Aeroquip socketless AN fittings / hose question brillo Engine, Exhaust, Transmission 1 07-14-2013 07:31 AM
Dual Catch Can, hoses and fittings Sportsguy83 Engine, Exhaust, Transmission 9 02-21-2013 01:13 AM
