Old 11-19-2017, 08:46 AM   #1
Eazy-V
Surging / Stciking Idle
I recently starting having an issue where the idle surges / sticks at around 2-3k rpm when I come to a stop if my clutch is depressed. The engine surges / sticks at 2-3k rpm then after a few seconds it will typically come back down to normal sub 1k rpm. I noticed that if I put the gear into neutral and release the clutch pedal it comes back to down to normal pretty much right away.
I have a ACT 6-puck clutch/prolite flywheel, so could it be that or a vacuum leak or something wrong with my EcuTek tune? Any ideas?
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Old 11-19-2017, 02:53 PM   #2
norcalpb
norcalpb's Avatar
My engine acted like that when I had an exhaust leak.
Old 11-19-2017, 03:16 PM   #3
humfrz
I suggest you lubricate the automatic choke mechanism with 3 in 1 oil, lubricate the throttle linkage with motor oil, inspect the clutch linkage to make sure it's not binding (and put in new cotter pins) and lubricate all moving joints with axle grease.
humfrz
Old 11-20-2017, 09:26 AM   #4
DJCarbine
Thupercharged
DJCarbine's Avatar
humfrz
Should he check the distributor as well? Might have thrown a weight on the mechanical timing advance, or ripped the vacuum advance diaphragm causing a leak.
OP, when is the last time you adjusted the idle mixture and set timing?
But seriously, can you get a datalog while it happens?
Much easier to troubleshoot with sensor data during the event, have you talked to your tuner ar all yet?
2013 FRS
Vortech V3 11psi
Old 11-20-2017, 11:48 AM   #5
humfrz
Good follow up!
Oh, my, hold up OP ......... I posted on the wrong forum ....... I thought I was on the 50s car forum ....... I'd better get back over there before that old dude goes crazy looking for the OBDII port, to do data logging .......
humfrz
Old 11-21-2017, 08:01 AM   #6
alan.chalkley
Drives: 4wd zooks
Mine was going nuts when the professional apprentice subaru mechanic used way too much throttle body cleaner during two of the routine services.
It fixed itself after a couple of days.
alan.chalkley is offline   Reply With Quote
Old 11-21-2017, 08:57 PM   #7
steve99
Log whats going on with ecutek cable if you have it
Check ltft it should be arround 5% or less if its like over 10% you likely have intake od exhaust leak
Afr at idle should be pretty close to 14.7
Ignition timing should ve arround 12 degrees after car warms up
The car will have faster idle on cold start , should onlt be for first few minutes then should settle to bg base idle of avout 700
Edit
I see your turbo , so could be a several other things with tune, ie could be speed density tune issue or flex sensor or bov leak, etc incoreectly scaled injecotrs. Best talk to tuner that did the work
Old 11-22-2017, 05:03 AM   #8
Eazy-V
Ok thanks for the info, hopefully I have time this week to look into it further.
AC hot air during idle Initial_RD Issues | Warranty | Recalls / TSB 13 07-30-2019 07:41 AM
E85 OFT tune Bucking/surging Vmax911 Software Tuning 5 07-30-2017 03:27 AM
Surging Idle RichardsFRS Issues | Warranty | Recalls / TSB 20 03-16-2016 06:47 AM
Idle dip but going FI mscamp02 Forced Induction 16 11-09-2015 03:16 PM
Idle at 4 psi? LS1M Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 07-18-2015 12:01 PM
