Old 11-16-2017, 01:09 PM   #1
BlackNBlue
Young Blood
Drives: 04 Wrx, 2014 Brz
Subaru’s synthetic oil?
Is this oil really good for 7000-7500 miles?
I bought the car @ 20,500 and they changed the oil for me, as of now i have 25,600 miles. Anyway I’m going to Houston this weekend and it’s a 300 mile drive from where I’m at, so total 600 miles back and forth.
Should i change the oil before or after i come back?
BlackNBlue is offline   Reply With Quote
Old 11-16-2017, 01:22 PM   #2
Vital
Drives: 2015 BRZ
Subaru actually recommends oil change after 6000 miles. You can choose to do it whenever sooner or later. You would be fine even if you did it after your Houston trip its really up to you.
EDIT: I forgot on MY13-14 it still says 7500 intervals for oil change even then you would still be fine if you did after your trip.
Vital is offline   Reply With Quote
Old 11-16-2017, 01:32 PM   #3
BlackNBlue
Young Blood
Great! Thanks for answering
Old 11-16-2017, 02:02 PM   #4
FirstWinter
Drives: Car
The only way to accurately tell is by getting an oil analysis. However if you're only commuting around you'll be fine. You could probably stretch it a lot more without issue. I generally change mine ~5K-7K miles but I track and drive the car hard on top of daily driving.
FirstWinter is offline   Reply With Quote
Old 11-16-2017, 02:04 PM   #5
RallySTI
Drives: 2013 Subaru BRZ
The Subaru 0w-20 that you can buy over the parts counter, comes in a gold colored gallon or quart bottle, is made by Idemitsu and is a good oil for daily use.
A lot of dealers including the Subaru dealer I was tech at uses a bulk 0W-20 oil, that they would source locally, so that they can use the pull down quick fill oil hoses. If you do not ask for specific oil you will get the "bulk" oil. It does not mean its total shit oil but it is not usually the same as the "Subaru" stuff that comes from the parts counter.
Somewhere along the line I was told that factory fill is Eneos .
RallySTI is offline   Reply With Quote
Old 11-16-2017, 02:18 PM   #6
humfrz
I don't reckon it much matters ....... your call.
humfrz
Old 11-16-2017, 02:22 PM   #7
If you do not change the oil per the schedule you run the risk of being denied warranty coverage should a possible oil related failure occur. The oil will outlast the change interval by quite a margin in a street driven car but it still needs to be changed at the "recommended" interval.
Old 11-16-2017, 08:34 PM   #8
cjny
Drives: 2016 BRZ
This.
cjny is offline   Reply With Quote
Old 11-16-2017, 08:37 PM   #9
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I recall seeing an oil analysis done with track use at 13k and it looked like it would keep going for a few more thousand miles.
Now the question of the filter is another story.
I still like doing regular oil changes to keep my engine feeling a bit smoother (probably a placebo effect) + fresh oil filter.
Old 11-17-2017, 10:55 AM   #10
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I'm going to break ranks and say change the oil if you have the chance. Not out of need, per se, but more out of opportunity. While the oil is very likely fine at this point, you still aren't exactly getting ripped off with a 5K oil change interval of an unknown fill. If I was about to take a 600+ mile trip of constant rpm and engine temp, I'd prefer a nice fresh additive package in there, doing it's best to keep a motor clean and shiny on the inside. If you have 5K miles of typical stop and go daily driving, it certainly wouldn't be a BAD thing to change it before you leave, if you had the chance..
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Sealant or Synthetic Wax aghuman Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 15 02-25-2014 05:45 PM
Subaru Synthetic oil 0w-20 alex_86 Mechanical Maintenance and Tools 1 09-27-2013 10:14 PM
Top Synthetic Oil for FRS...opinions? forzajuve Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 04-24-2013 12:33 PM
Is FR-S oil Synthetic or Conventional? EBMCS03 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 52 01-08-2013 11:37 PM
Subaru Oil All Synthetic? DaJo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 11-07-2012 11:47 AM
