Old 10-17-2012, 09:55 PM   #1
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Subaru Oil All Synthetic?
I just purchased a case of Subaru oil for my car's first oil change... Which will be done by me.
When I got home I realized they gave me the 0W-20 Synthetic oil...
I called them back and asked if they gave me the wrong box, assuming I only need the normal conventional oil because the engine is still fairly new. They replied that that is the right oil to be used for the BRZ.
Anyways, my question is...Are ALL Subaru engine oil by-default Synthetic?
Thanks in advance!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 10-17-2012, 10:47 PM   #2
Le86
Drives: Asphalt FR-S
Not all but the vast majority of "Subaru oils" are synthetics. Your car comes from the factory with synthetic, not conventional.
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
Le86 is offline   Reply With Quote
Old 10-17-2012, 10:50 PM   #3
Jimbo
Jimbo's Avatar
Drives: 92 NSX, 08 Accord
Why wouldn't you want synthetic for the first change? Are you doing a change with very minimal miles - like less than 1,000 - and are concerned about the so-called break-in oil? If so, I'd wait - or just change the filter if you want to be extra fussy.
1992 NSX Red/Blk 5 spd #0330
2005 Lotus Elise - (sold but reincarnated by BRZ)
2008 Honda Accord Cpe, Blk/Blk,V6,6 spd, Nav (sold)
2013 Subaru BRZ, Limited, 6 spd Auto, WR Blue
Jimbo is offline   Reply With Quote
Old 10-18-2012, 09:06 AM   #4
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Even the breakin oils are usually synthetic, they just have different additives and may be a different weight.
Using a synthetic is pretty much always better. It has a more constant molecular structure so it maintains its designed properties better and experiences less breakdown over time.
Old 10-18-2012, 09:26 AM   #5
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Technically speaking nearly all oils marketed as "synthetic" are actually highly refined dinosaur oil. The only oils that I can think of that are truly synthetic are AmsOil and Redline.
The reason for this is that there was a court case where Mobil sued another manufacturer claiming that the other company's "synthetic"-marketed oil was highly refined dinosaur oil whereas MobilOne (at the time) was true synthetic, and much more expensive. The court ruled that the term 'synthetic' was a marketing term and could be used by highly-refined dinosaur oils.
Dont sweat it.
Grimlock is offline   Reply With Quote
Old 10-18-2012, 09:26 AM   #6
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Yep, every 2013+ Subaru runs synthetic at this point.
Impreza, Sport, XV, BRZ, Forester and Outback - 0W-20 Synthetic
WRX/STi - 5W-30 Synthetic
Tribeca - 5W-30 Conventional but Subaru reccomends Synthetic
Beyer Subaru is offline   Reply With Quote
Old 10-18-2012, 10:33 AM   #7
DaJo
FT86Club Vancouver
DaJo's Avatar
Perfect! Thank you everyone! <3:happy0180:
2000 MR-S 5MT
2010-2012
Old 10-18-2012, 12:08 PM   #8
bluesubie
Dont sweat it.
Technically speaking conventional oil, nor Group III oils, are made from dinosaur oil or dinosaur fossils. Also, it's a common misconception that there was a Mobil lawsuit, and that there was a court case, but there was only a "ruling" by the National Advertising Division of the Better Business Bureau.
When speaking of Amsoil, note that their OE and XL lines are made from Group III base stocks. Of course, what matters most is the complete package (base stocks and additives) and the oil's end performance.
DaJoian - Can you check if the oil is API SM or SN? Just curious.
-Dennis
bluesubie is offline   Reply With Quote
Old 10-18-2012, 12:18 PM   #9
DaJo
FT86Club Vancouver
DaJo's Avatar
-Dennis
I will do that and report back to you as soon as I can. Thanks!
2000 MR-S 5MT
2010-2012
Old 10-18-2012, 01:35 PM   #10
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Dont sweat it.
99% sure Pennzoil Ultra is a group IV base oil, as well as Rotella T6.
Ranatsu is offline   Reply With Quote
Old 10-18-2012, 01:45 PM   #11
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
You're right.
http://www.bobistheoilguy.com/forums...=950368&page=1
But the results were the same. Group III oils can be called synthetic and a lot of companies started using Group III instead of PAOs in their synthetic oils.
Old 10-18-2012, 01:56 PM   #12
bluesubie
Pennzoil has said that all Ultra is PAO Group IV, but RT6 is Group III.
-Dennis
Old 10-18-2012, 02:53 PM   #13
Ranatsu
Cone basher
-Dennis
Yep you are correct.
Old 10-18-2012, 02:56 PM   #14
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
All 0-20 weight oil is synthetic.
blu_ is offline   Reply With Quote
0W-20 full synthetic oil for $3.49 a quart terrypm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 04-08-2014 04:51 PM
Royal Purple Synthetic Motor Oil 0w20 for the FR-S/BRZ at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 5 12-29-2012 04:25 PM
%100 Full Sythentic VS Fully Synthetic ProjectD Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 10-05-2012 01:28 PM
Subaru BRZ - RAW Subaru | Official Subaru Australia Ad Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 15 07-20-2012 08:20 AM
Royal Purple Synthetic Motor Oil 0w20 for the FR-S/BRZ at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 3 07-08-2012 01:04 PM
