Drives: '13 BRZ Limited / 76' 914 1.8T
OLM Bixenon Low / High Beam Projector Fog Lights Installation
I picked up the OLM Bixenon Low / High Beam Projector Fog Lights to reveal the wooded surroundings at night on the way back from mountain biking - almost hitting deer every time is far from ideal.
I did some searching and haven't been able to find the locations for the following plugs: "To stock high beam" "High beam input from vehicle" "Fog light input from vehicle" If someone could shine some light on the locations for me I'll happily post up a review after.
Automotive photo and video
www.mikespock.com |
ಠ_ಠ
Drives: 860 SansOverspray
Here's the headlight harness pinout for a '13 BRZ.
White = Turn signal + Green = Boomerang LED + Thin Black = Common Ground Yellow = High beam + Red = Low beam + Thick Black = Low beam ground Blue = High beam ground You will need to tap your hi beam input connector into the YELLOW and BLUE wires. As for the stock fogs, if you didn't have any, look at the fog installation howto to get the wiring details. http://www.ft86club.com/forums/showthread.php?t=27581 |
Are those harness plugs not intended to plug directly into the factory plugs?
www.mikespock.com |
ಠ_ಠ
Can you show us the actual harness kit you got with the fogs?
ಠ_ಠ
If you mean you have this harness: http://www.ft86speedfactory.com/olm-...2013-ft86.html
Your BRZ has factory HID, you don't have the hi beam plug that this kit is for. It's not going to be plug and play. |
#6 | |
Where am I tapping in to the "fog light input from vehicle" as I'm not seeing a matching plug - or will that require custom wiring as well?
www.mikespock.com |
Drives: 2015 Series.Blue
At this point I just need to know where to tap for the "fog light input from vehicle"
www.mikespock.com |
Can anyone answer this question? I'd like to install this weekend.
www.mikespock.com |
| OLM bixenon fog light and wiring harness for fog with high beams | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 42 | 08-10-2016 01:46 PM |
| Dash lights and high beam icon are on but.. | GT 86 Brah | Issues | Warranty | Recalls / TSB | 3 | 06-28-2016 12:18 AM |
| OLM Bixenon Projector Foglights:Review | 15limited | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-31-2015 10:48 PM |
| Scion FRS H11 Projector Low beam CREE LED replacement | dssence | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 04-08-2014 11:18 PM |
| *PHASTEK* High / Low Beam Fog Lights for the FR-S & BRZ | PhastekSport | Exterior Parts - Lighting | 35 | 01-06-2014 10:23 AM |
