Old 10-31-2017, 11:57 PM   #1
FutureFT86
FutureFT86's Avatar
Drives: 13 Scion FR-S
Sparco Evo - Which size is right for me?
Hi guys,
I don't have much of a choice where I live to try out the Sparco Evo seat sizes to see which suits me best.
I'm 5'8" tall, 131 lbs' and about a 30 waist. Small guy you can say.
I'm looking into a regular Evo Medium seat as I believe the Evo II US or Evo III would be too large.
Can anyone guide me in the right direction?
Thanks
Mike
Sent from my SM-G930W8 using Tapatalk
Check out my build: Instagram @kawallito
FutureFT86 is offline   Reply With Quote
Old 11-01-2017, 08:25 AM   #2
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
5'11" 200lbs, 34" waist and the Sparco Evo 2 is just right for me. I would say for a DD it would be too snug, but for a race car it's perfect. (It's not in my 86.)
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 11-01-2017, 10:12 AM   #3
e1_griego
e1_griego's Avatar
Drives: Many
OP: The normal Evo is probably the one you want.
e1_griego is offline   Reply With Quote
Old 11-01-2017, 01:53 PM   #4
ChiTownFrs
ChiTownFrs's Avatar
Drives: 2013 Ultramarine FRS
I run the Standard EVO in my car. I'm 5'11 with a 34 waist and the seat is snug for me. But it has been perfect for track use when I remove the cushion.
ChiTownFrs is offline   Reply With Quote
Old 11-01-2017, 08:49 PM   #5
ryoma
ryoma's Avatar
I would recommend the Sparco REV if you're a smaller frame.
Old 11-01-2017, 09:07 PM   #6
FutureFT86
FutureFT86's Avatar
Oh thanks never considered that one
Sparco seat mount and Sparco sliders for FRS/BRZ justinco Interior Parts (Incl. Lighting) 8 07-13-2016 07:35 PM
Sparco wheels F3dzo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 05-19-2014 12:23 AM
sparco wheel help ft86me Cosmetic Modification (Interior/Exterior/Lighting) 0 06-07-2013 11:24 PM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 08:41 PM
