Old 10-27-2017, 10:30 AM   #1
ILLSMOQ
Drives: 2017 WR BLUE BRZ
LS swap oil pan
Have we figured out the best choice on the oil pan yet?
I have the later GTO pan GM #12599397 on my engine already but if there is a better choice I’d like to swap it out before I put the engine in.
ILLSMOQ is offline   Reply With Quote
Old 10-27-2017, 10:35 AM   #2
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I would say the earlier GTO pan or one of the swap pans would be a good idea. As it stands, I am going to have to remove mine and have it cut/welded to clear a sway bar.
DustinS is offline   Reply With Quote
Old 10-28-2017, 02:30 PM   #3
ILLSMOQ
Why not buy one of the other pans instead?
Old 10-28-2017, 09:32 PM   #4
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
The Sikky swap pan fits well but I have seen some leaky corners and what not from the welds. And the oil filter fittings are very close to the subframe depending on how you tilt the engine
Pure Automotive is offline   Reply With Quote
Old 10-28-2017, 10:03 PM   #5
ILLSMOQ
A/C fits okay with the sikky pan? Ground clearance is good right?
@DustinS your GTO pan hangs pretty low right?
Old 10-29-2017, 08:46 AM   #6
Pure Automotive
Yea we had AC on the lower left of the engine bay with it, it's very flat on the bottom. Email me and I'll try to get you a hookup on it, they are about 30 min from me.
Old 10-29-2017, 09:12 AM   #7
ILLSMOQ
Great thanks! What is the application for the AC compressor you used?
Old 10-30-2017, 09:16 AM   #8
DustinS
DustinS's Avatar
Yeah. I've hit it on something already... Luckily just a brush and didn't hurt anything. I have just been lazy getting my undertray cut to fit.
Old 10-30-2017, 10:07 PM   #9
wooly35
Drives: 2014 Scion FR-S LS3
guess I was lucky that I never hit the oil pan when the cover was off. I now have the metal pan on... had to hammer out the front part to keep the oil pan from rubbing. Other than that, the gto oil pan has done just fine.... but don't forget to cut down the two wings in the back that slightly hit the steering column!
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
Old 10-31-2017, 01:40 AM   #10
Merc
Drives: Subaru brz 2013 LS1 swap
Good stuff to know starting an ls 1 swap this month. I know about the transmission tunnel modifications but have been reading mixed things about certain other clearances. Steering rack and sway bar are my biggest concerns.
Merc is offline   Reply With Quote
Old 11-06-2017, 01:31 PM   #11
ILLSMOQ
You guys have any good pics of that gto pan in the car?...I want to see what the ground clearance and other clearances look like.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
2JZ Swap Kit? Moe23 Engine Swaps 37 10-27-2016 07:04 PM
Before you do a 2JZ swap.. Manji Engine Swaps 25 03-14-2015 04:32 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
AT swap to MT CodyFRS Engine, Exhaust, Transmission 25 10-30-2013 10:39 PM
