Old 02-14-2015, 05:41 AM   #1
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Before you do a 2JZ swap..
I keep seeing 2jz swaps coming up on my news feed, and don't get me wrong I think that's great, but really surprised more aren't going 1uz TT.
2jz's come with a manual box, and factory turbo, 1uz's don't have either. But the aftermarket has shown these to not be issues.
You can buy bellhousing conversion kits to bolt the good toyota manual boxes to a 1uz.
The early generation 1uz's (non vvti) have proven time and time again to reliably take 600hp+ unopened, twice that if built.
1uz pros over 2jz
1000cc more displacement
75kg lighter
Cheaper
Shorter
Depending on your plans with the 1uz, governs which gen you buy. The early gen model (non vvti) have a stronger bottom end. If you don't want to build them, and just use stock motors, get an early gen.
If you're going to build it, get the vvti model. It has a far better head, but the rods are weaker.
So, why don't more people put 1uz's and twin turbo them, compared with 2j swaps, in other platforms? The 1uz is a big bitch. But again, remember it's quite a bit lighter than a 2jz. It's because there isn't the room. A lot of cars barely have room the 1uz itself, and need horrible "block hugger" headers to fit in, certainly not enough room for turbos.
BUT, the beauty of the gt86 is that it has a boxer. So the engine bay is very wide. Easily wide enough for a 1uz and a gtx28 or gtx30 either side of it.
1uz turbo setups are becoming more and more popular in the drift scene over here. Because of the reasons above, strong but still cheap. But the ones I've seen are in silvias, and because their bay isn't wide enough for TT, they have to do this ugly 8 into 1 setup with the turbo forward of the motor.
Here's a front on shot of my car. Look at the room we had for the headers. Easily enough room for a pair of snails.
Someone do it!
Manji is offline   Reply With Quote
The Following 15 Users Say Thank You to Manji For This Useful Post:
aagun (02-20-2015), adamg (02-16-2015), Astroboy (08-20-2017), civicdrivr (02-19-2015), CxG (10-27-2015), DustinS (02-16-2015), Fakk (02-14-2015), Jacques Blom (02-15-2015), Jive Turkey (03-17-2015), Koa (02-16-2015), Lonewolf (02-18-2015), Manic (02-17-2015), Marx (02-17-2015), nguyen_er (02-14-2015), Teseo (02-17-2015)
Old 02-14-2015, 06:42 AM   #2
denso
Drives: 86
Hi,
im wondering why nobody is looking for a 2GR swap. This engine got so much potential and is even smaller than a V8 an lighter of course.
denso is offline   Reply With Quote
The Following 3 Users Say Thank You to denso For This Useful Post:
1GiantTurtle (02-18-2015), Astroboy (08-20-2017), hmong337 (02-14-2015)
Old 02-14-2015, 06:45 AM   #3
nguyen_er
nguyen_er's Avatar
Drives: 2013 Raven FR-S
Do you have a build thread?
nguyen_er is offline   Reply With Quote
Old 02-16-2015, 09:24 AM   #4
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
The matter of 2JZ vs 1UZ is preference.
Both capable engines. I like how my 2JZ has more room than the 1UZ.
slicktop is offline   Reply With Quote
Old 02-16-2015, 10:00 AM   #5
Koa
Originally Posted by Manji View Post
1uz pros over 2jz
75kg lighter
Cheaper
Shorter
big ups for a solid first look at the benefits and feasibility of the 1uz, able to be followed easily and arguments non-emotional, straight perspective
The Following User Says Thank You to Koa For This Useful Post:
Manji (02-17-2015)
Old 02-16-2015, 10:15 AM   #6
adamg
Drives: brz
i applaud anyone that has the guts to do an engine swap on one of these cars. Pulling a brand new motor is insane
adamg is offline   Reply With Quote
The Following 6 Users Say Thank You to adamg For This Useful Post:
AVodka14 (02-16-2015), Caspeed (02-18-2015), hmong337 (02-17-2015), MokSpeed (02-18-2015), OmarGC (02-19-2015), The Feds (06-22-2015)
Old 02-16-2015, 11:30 AM   #7
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I want to do a 1uz swap eventually. If you could post as many pictures as possible. This swap looks really good.
DustinS is offline   Reply With Quote
Old 02-17-2015, 04:45 AM   #8
Tomita San
Tomita San's Avatar
Drives: Scion FR-S
Originally Posted by denso View Post
Hi,
2GRs are not THAT great. They are too tall to fit in the engine bay, mostly because the complicated 3 stage VVTi head, they are not that light either.
Although dual-vvti, they don´t like to rev too high, and suffer from mysterious VVTi-gear knock, that nobody can fix ..just have to live with it.
I´ve got one in my Aurion (AUS Camry) and another in pieces lying around the garage
As for fitment, better look for the older (and simpler) 3MZ-FE..
Tomita San is offline   Reply With Quote
Old 02-17-2015, 06:53 AM   #9
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
More pics!!
Yamajee is offline   Reply With Quote
Old 02-17-2015, 01:06 PM   #10
UtahSleeper
UtahSleeper's Avatar
Drives: 80 Corolla 88 Celica Alltrac 13 FRS
If this motor had more parts to easily convert to rwd, I would be all over for my te72. Everything I have seen is it is a pain to convert(relocating starter, adapter plate for trans, etc).
UtahSleeper is offline   Reply With Quote
Old 02-17-2015, 08:02 PM   #11
Poodles
Drives: 2015 Series.Blue
The issue with the 1UZ has always been lack of performance parts. They're great if you're a fabricator or can afford to have that stuff custom done...
In the Supra world it's kinda laughed at because it's a whole lot of hassle for only 1.0 liter difference. Same amount of work, better aftermarket support, and more engine bay room with an LS motor
Waiting for someone to toss a 3UR in one of these cars... but again, expensive...
Old 02-18-2015, 12:10 AM   #12
inertia
inertia's Avatar
A majority of these guys are purchasing their BRZ/FRS chassis from salvage auctions. I seriously doubt they are purchasing brand new or slightly used donors for their project.
inertia is offline   Reply With Quote
Old 02-18-2015, 01:54 AM   #13
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
Hi,
I love the 2gr series engines however the 2gr-fse is too tall a custom intake manifold needs to be created
as seen here
Tom's did it!
Some one used a 3gr-fse again a custom manifold must be created
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 02-18-2015, 05:43 PM   #14
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
This.
I wouldn't even contemplate it until my motors sees close to 100,000 miles.
MokSpeed is offline   Reply With Quote
The Following User Says Thank You to MokSpeed For This Useful Post:
BlueDubbinTDI (02-20-2015)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
LED swap Skorov AUSTRALIA 28 09-23-2014 09:46 PM
BRZ Swap!!!! EnviedIke Engine Swaps 59 07-30-2014 06:32 PM
Looking for an STi Swap Doug@WGP NY / NJ / CT / PA 31 11-27-2012 12:54 AM
2UR-GSE Swap czar07 Engine Swaps 9 08-29-2012 01:43 PM
