Drives: 2016 Scion FRS Halo
What state should the car be in when reading the overflow reservoir?
When the car is off and cold, the overflow reservoir shows a lower reading versus when the car is on and warmed up.
This is confusing because when the car is cold, it can be said that coolant needs replenishing, but after the car is warmed up, it can be said that it does not need replenishing, so which one is right? What state should the car be in when reading of the overflow reservoir, to make sure it is at the optimum level? |
Weight Weenie
Drives: 15 FR-S
![]() ^^See the lines on the overflow? If you're somewhere between them you're |
The Gunshine State
Drives: '14 BRZ Limited
The level will vary, like you're noticing. As long as it's lowest point isn't below the minimum line and highest point isn't above the maximum line you're good.
![]() Current DD: M235i |
What state of the car though? There's literally two different readings. How do I know what reading to look at to make sure I'm in the optimum range?
#5 | |
The Gunshine State
You are probably over-thinking this, is the car overheating at a long idle? If not, you're good to go.
I should have just read the manual before posting. It says while cold.
/thread |
| Tags |
| coolant, overflow reservoir |
| Gas Tank Overflow and Gauge Issues | KPDoubleX | CANADA | 12 | 11-13-2022 06:53 PM |
| Mishimoto Coolant Overflow Tank R&D | Mishimoto | Engine, Exhaust, Transmission | 25 | 04-29-2017 11:57 PM |
| Looks like coolant sprayed out of the overflow during motorkhana | nomis | Issues | Warranty | Recalls / TSB | 5 | 10-27-2015 10:56 AM |
| Perrin Overflow Sale!! Low Pricing While Supplies Last!! | Mike@CZP | Engine, Exhaust, Bolt-Ons | 64 | 06-18-2015 10:10 AM |
| Racer X Fabrication, coolant overflow tank | Jeff@Racer X Fab | Engine, Exhaust, Transmission | 5 | 06-08-2015 02:28 PM |
