Old 10-23-2017, 07:57 PM   #1
ghostzfh
Drives: 2016 Scion FRS Halo
What state should the car be in when reading the overflow reservoir?
When the car is off and cold, the overflow reservoir shows a lower reading versus when the car is on and warmed up.
This is confusing because when the car is cold, it can be said that coolant needs replenishing, but after the car is warmed up, it can be said that it does not need replenishing, so which one is right?
What state should the car be in when reading of the overflow reservoir, to make sure it is at the optimum level?
ghostzfh is offline   Reply With Quote
Old 10-23-2017, 08:02 PM   #2
new2subaru
Weight Weenie
Drives: 15 FR-S
^^See the lines on the overflow? If you're somewhere between them you're
Old 10-23-2017, 08:06 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
The level will vary, like you're noticing. As long as it's lowest point isn't below the minimum line and highest point isn't above the maximum line you're good.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 10-23-2017, 11:19 PM   #4
ghostzfh
What state of the car though? There's literally two different readings. How do I know what reading to look at to make sure I'm in the optimum range?
Old 10-24-2017, 08:20 AM   #5
8RZ
The Gunshine State
8RZ's Avatar
Like I said, both readings should be within the max and min fill lines. If it's below the min line at it's lowest point then add more coolant.
You are probably over-thinking this, is the car overheating at a long idle? If not, you're good to go.
Current DD: M235i
Old 10-24-2017, 12:39 PM   #6
ghostzfh
I should have just read the manual before posting. It says while cold.
/thread
The Following User Says Thank You to ghostzfh For This Useful Post:
22R (10-24-2017)
Old 10-24-2017, 12:48 PM   #7
/thread
coolant, overflow reservoir
Gas Tank Overflow and Gauge Issues KPDoubleX CANADA 12 11-13-2022 06:53 PM
Mishimoto Coolant Overflow Tank R&D Mishimoto Engine, Exhaust, Transmission 25 04-29-2017 11:57 PM
Looks like coolant sprayed out of the overflow during motorkhana nomis Issues | Warranty | Recalls / TSB 5 10-27-2015 10:56 AM
Perrin Overflow Sale!! Low Pricing While Supplies Last!! Mike@CZP Engine, Exhaust, Bolt-Ons 64 06-18-2015 10:10 AM
Racer X Fabrication, coolant overflow tank Jeff@Racer X Fab Engine, Exhaust, Transmission 5 06-08-2015 02:28 PM
