Old 10-17-2017, 12:17 PM   #1
Dee
Drives: 2014 Asphalt FRS
17x9 Tire question
What are the pros and cons of running 225, 235, and 245? And sidewall?
I have 17x9 +42 wheels on the way.
Also I plan on lowering the car. Not slamming it but I want to rid of some wheel gap. Might even go springs.
Car is a daily driver so I like to keep it pretty pratical and simple.
Thank you for your time!
Dee is offline   Reply With Quote
Old 10-17-2017, 12:26 PM   #2
jasonojordan
Drives: 2013 satin white brz limited
Well on a 9" wheel I can tell you right now you can't run a 225 without stretching the hell out of it.Even then don't think a 225 would fit. Similar story with most 235 Tires. I would not run anything smaller then a 245 on a 9" wheel.
jasonojordan is offline   Reply With Quote
Old 10-17-2017, 12:44 PM   #3
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Go a minimum of 245, unless you want stretched tires. 245/40/17 is very close to the diameter of 215/45/17.
G_Ride is offline   Reply With Quote
The Following 3 Users Say Thank You to G_Ride For This Useful Post:
86Ryan (10-20-2017), Clipdat (10-17-2017), strat61caster (10-17-2017)
Old 10-17-2017, 12:57 PM   #4
Dee
Thank you guys
/thread
The Following User Says Thank You to Dee For This Useful Post:
15limited (10-19-2017)
Old 10-17-2017, 01:01 PM   #5
Trust86
Drives: 2016 Halo FRS
It honestly depends on what tire you run. Some run a lot wider than others. A 225 tire with a 45 sidewall will fit and have some stretch. Recommend tire size for a 17x9 is 235-265.
Trust86 is offline   Reply With Quote
The Following User Says Thank You to Trust86 For This Useful Post:
Icecreamtruk (10-17-2017)
Old 10-17-2017, 02:10 PM   #6
Icecreamtruk
Drives: Track preped NA FRS
Greatly dependant on tire and sidewall height as Trust86 stated. For example, a 245/40R17 Hankook RS4 is flat (no stretch, no bulge) on a 17x9 wheel, but a MPSS in the exact same dimensions has a very small stretch to it. 235/40 will look more or less the same as 225/45 in terms of stretch (there is some, still acceptable).
I would personnaly go between 235 and 245, but not higher than 255 and lower than 225. With 45 profile for 225 and 40 for everything else.
Old 10-17-2017, 02:21 PM   #7
sachu
Drives: rocketship
am in the same boat. planning on going with Continental ExtremeContact Sport in 255/40.
sachu is offline   Reply With Quote
Old 10-17-2017, 02:28 PM   #8
jasonojordan
I ran these the set before what I am not. Good over all daily driving tire. Good enough grip for most situations. Handles water well. Be careful as the temps outside dip down around 40f anything under that they can be a bit greasy till you get them warm.
The Following User Says Thank You to jasonojordan For This Useful Post:
sachu (10-18-2017)
Old 10-17-2017, 07:11 PM   #9
rt
@rayhere
rt's Avatar
I have 255 RS3s and love how flat and square the sidewall and shoulders look. But as other posters have mentioned, each tire will fit slightly differently.
rt is offline   Reply With Quote
The Following 2 Users Say Thank You to rt For This Useful Post:
DuMa (10-25-2017), Kami Speed (10-18-2017)
Old 10-17-2017, 07:52 PM   #10
sam69
Drives: GT 86
I've just been through the same exercise and finished up with 245 40's as I was sold on the Michelin PS4 and they only make them in 245 and not 255.
The PS4 has ever so slight stretch to the sidewall but not much but I'm more than happy and very impressed with these tyres (tires ).
sam69 is offline   Reply With Quote
Old 10-18-2017, 02:30 AM   #11
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I've ran 255~235 on a 9" wide wheel. I'm currently on my 4th set of 235 wide tires, IIRC. They're only slightly stretched. Works perfectly fine.
Intent > Content
Old 10-18-2017, 08:21 AM   #12
jasonojordan
This is very tire dependent. Some run wider then others. What tires are you running on your 9"
Old 10-18-2017, 01:13 PM   #13
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have 245's that measure 225. I also have had 225 that measure 245. Totally what tire you run.
I ran 3 sets of 245/40/17 MPSS. Great all around tire. I can also say the A/S3 is a good choice.
I LIKE TIRES!
Old 10-18-2017, 02:04 PM   #14
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
That is an amazing pic of the new CRs. Awesome shot man
Kami Speed is offline   Reply With Quote
The Following User Says Thank You to Kami Speed For This Useful Post:
rt (10-18-2017)
Best tire size for 17x9 wheels Elliotw Tracking / Autocross / HPDE / Drifting 3 09-30-2017 01:22 AM
Good Tire size for 17x9? J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-05-2016 08:30 AM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 01:44 PM
Nubby wheel/tire/fitment guy in need of advice 17x9+35 KevinK121 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2015 07:34 AM
The rite tire size? rpf1 17x9 +45 Gillams Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 04-22-2015 12:37 PM
