Drives: 14 BSP Edelbrock BRZ
Who wants a TALLER MFactory 6th gear
I contacted MFactory about producing a taller (.687) 6th gear. For those with the OEM rear end this will put you at 78 mph in 6th gear at 3000 rpm. For those with shorter rear ends, do the math
![]() They responded that due to their forging process it is only economical if they do a batch of 30 units. Same price as their shorter 6th, $360, and they will make it so it slides right on to the shaft without any case modifications. I would like to get a head count of those interested. Replies of 'I might be' are not helpful... |
| The Following 7 Users Say Thank You to toast For This Useful Post: | atomicalex (08-13-2019), chaoskaze (12-22-2018), DAEMANO (10-18-2017), jcw99 (01-11-2019), nav (10-18-2017), Spawn_Of_Creation (10-20-2017), yberther (11-10-2018) |
Drives: 15 BRZ LTD, 05 FXT
Sounds awesome for guys with a lot of highways and long straights in their area, or big power folks trying to keep the RPM's down.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
Drives: Toyota 86
Hey Toast, that is an awesome idea - especially for those who decide to run a shorter final drive. I'll use my car with some back of the napkin numbers:
Original: 4.1 Final Drive Gearing Torque Increase: 0% Highway Crusing @ 70mph: 3000rpm Current: 4.8 Final Drive Gearing Torque Increase: 17% (all gears) Highway Crusing @ 70mph: 3500rpm Proposed: 4.8 Final Drive (with 0.687 / 6th Gear) Gearing Torque Increase: 17% (gear 1-5) Highway Crusing @ 70mph: 3150rpm Given the usage of my car, I do like the idea of sacrificing the final gear of the vehicle as an 'overdrive' gear. Great initiative Toast! |
| The Following 5 Users Say Thank You to nav For This Useful Post: | atomicalex (08-13-2019), Feistyfrog (08-13-2019), jcw99 (07-27-2018), Pekingduck (10-23-2017), Tristor (08-13-2019) |
Human
Drives: 2015 BRZ Black
I posted my few cents and interest in another thread (http://www.ft86club.com/forums/showt...php?p=2984138#) about a month ago. I'll commit to this.
some numbers for those who are curious ~ Final Drive 3.73:1 @ 3000 rpm: Custom 0.687 ratio 6th gear = 86mph Stock 6th gear = 77mph MFactory short 6th gear = 68mph (Stock) Final Drive 4.1:1 @ 3000 rpm: Custom 0.687 ratio 6th gear = 78mph Stock 6th gear = 70mph MFactory short 6th gear = 62mph Final Drive 4.44:1 @ 3000 rpm: Custom 0.687 ratio 6th gear = 72mph Stock 6th gear= 65mph MFactory short 6th gear= 58mph Final Drive 4.55:1 @ 3000 rpm: Custom 0.687 ratio 6th gear = 70mph Stock 6th gear = 63mph MFactory short 6th gear = 56mph Final Drive 4.67:1 @ 3000 rpm: Custom 0.687 ratio 6th gear = 68mph Stock 6th gear = 61mph MFactory short 6th gear = 55mph Final Drive 4.8:1 @ 3000 rpm: Custom 0.687 ratio 6th gear = 67mph Stock 6th gear = 60mph MFactory short 6th gear = 53mph
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
| The Following 5 Users Say Thank You to Spawn_Of_Creation For This Useful Post: | atomicalex (08-13-2019), jcw99 (07-27-2018), nav (10-19-2017), turbocat (10-24-2017), why? (10-24-2017) |
Only happy when it rains.
Drives: series.blue
what would be the speed at 2500 rpm or 2000 rpm with the stock final drive? I've been thinking about this, 6th gear seems all wrong for US speeds. And with the final drive mods it makes it even worse.
The Dictater
Drives: '13 Red Scion FRS
I wished 6th, and maybe even 5th, was a bit taller for a while as my commute is mostly highway. Though I'm not sure the install time/cost is worth it to me.
#7 | |
Drives: Black BRZ
At 2000 rpm you would be going 52, etc |
| The Following User Says Thank You to tshrey For This Useful Post: | why? (10-24-2017) |
Drives: Toyota GT86
I posted on the other thread somehow but anyway, I'm interested in a taller 6th gear or even a whole gear set. But I doubt we'll get 28 other people committed.
Sent from my Pixel XL using Tapatalk |
Drives: series.blue
#10 |
Drives: 2013 FRS
Was there any other movement on this product? It would be awesome to get a taller 6th gear.
Sent from my Moto Z (2) using Tapatalk |
#11 |
Drives: 2016 Oceanic, "base" model
Hmmm... first time I've seen this thread.
How is the quality/durability (based on experiences with shorter gears)? I've been casually looking for an M85, IS300 LSD rear end to lower my highway RPMs. But this would affect all gears and the speedo. A taller 6th gear is better approach. For $360, I'm in. |
| The Following User Says Thank You to MrDinkleman For This Useful Post: | jcw99 (11-16-2018) |
#12 | |
LMGTFY
Drives: 13 FRS, 91 Miata
#13 |
| The Following User Says Thank You to MrDinkleman For This Useful Post: | 86Tony (04-25-2019) |
#14 |
LMGTFY
Yep.
Change all the gears you want. The speedo should read correct if the tire size is the same. |
| Taller 6th gear? | tshrey | Engine, Exhaust, Transmission | 6 | 10-24-2017 06:09 AM |
| Do Automatics have Taller Gears | ItzYaBoyBugZ | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 05-31-2015 01:42 PM |
| taller final drive ratio | SuperDave | Engine, Exhaust, Transmission | 17 | 10-26-2014 04:37 PM |
| Anyone running taller tires? | cactus | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 02-04-2014 04:22 AM |
| Would a taller / larger oil filter improve oil cooling? | brillo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 05-14-2013 04:18 AM |
