Old 10-17-2017, 10:39 AM   #1
toast
Drives: 14 BSP Edelbrock BRZ
Who wants a TALLER MFactory 6th gear
I contacted MFactory about producing a taller (.687) 6th gear. For those with the OEM rear end this will put you at 78 mph in 6th gear at 3000 rpm. For those with shorter rear ends, do the math
They responded that due to their forging process it is only economical if they do a batch of 30 units. Same price as their shorter 6th, $360, and they will make it so it slides right on to the shaft without any case modifications.
I would like to get a head count of those interested. Replies of 'I might be' are not helpful...
toast is offline   Reply With Quote
The Following 7 Users Say Thank You to toast For This Useful Post:
atomicalex (08-13-2019), chaoskaze (12-22-2018), DAEMANO (10-18-2017), jcw99 (01-11-2019), nav (10-18-2017), Spawn_Of_Creation (10-20-2017), yberther (11-10-2018)
Old 10-17-2017, 10:44 AM   #2
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Sounds awesome for guys with a lot of highways and long straights in their area, or big power folks trying to keep the RPM's down.
JazzleSAURUS is offline   Reply With Quote
Old 10-18-2017, 10:14 PM   #3
nav
Drives: Toyota 86
Hey Toast, that is an awesome idea - especially for those who decide to run a shorter final drive. I'll use my car with some back of the napkin numbers:
Original: 4.1 Final Drive
Gearing Torque Increase: 0%
Highway Crusing @ 70mph: 3000rpm
Current: 4.8 Final Drive
Gearing Torque Increase: 17% (all gears)
Highway Crusing @ 70mph: 3500rpm
Proposed: 4.8 Final Drive (with 0.687 / 6th Gear)
Gearing Torque Increase: 17% (gear 1-5)
Highway Crusing @ 70mph: 3150rpm
Given the usage of my car, I do like the idea of sacrificing the final gear of the vehicle as an 'overdrive' gear. Great initiative Toast!
nav is offline   Reply With Quote
The Following 5 Users Say Thank You to nav For This Useful Post:
atomicalex (08-13-2019), Feistyfrog (08-13-2019), jcw99 (07-27-2018), Pekingduck (10-23-2017), Tristor (08-13-2019)
Old 10-19-2017, 12:12 AM   #4
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
I posted my few cents and interest in another thread (http://www.ft86club.com/forums/showt...php?p=2984138#) about a month ago. I'll commit to this.
some numbers for those who are curious ~
Final Drive 3.73:1 @ 3000 rpm:
Custom 0.687 ratio 6th gear = 86mph
Stock 6th gear = 77mph
MFactory short 6th gear = 68mph
(Stock) Final Drive 4.1:1 @ 3000 rpm:
Custom 0.687 ratio 6th gear = 78mph
Stock 6th gear = 70mph
MFactory short 6th gear = 62mph
Final Drive 4.44:1 @ 3000 rpm:
Custom 0.687 ratio 6th gear = 72mph
Stock 6th gear= 65mph
MFactory short 6th gear= 58mph
Final Drive 4.55:1 @ 3000 rpm:
Custom 0.687 ratio 6th gear = 70mph
Stock 6th gear = 63mph
MFactory short 6th gear = 56mph
Final Drive 4.67:1 @ 3000 rpm:
Custom 0.687 ratio 6th gear = 68mph
Stock 6th gear = 61mph
MFactory short 6th gear = 55mph
Final Drive 4.8:1 @ 3000 rpm:
Custom 0.687 ratio 6th gear = 67mph
Stock 6th gear = 60mph
MFactory short 6th gear = 53mph
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
The Following 5 Users Say Thank You to Spawn_Of_Creation For This Useful Post:
atomicalex (08-13-2019), jcw99 (07-27-2018), nav (10-19-2017), turbocat (10-24-2017), why? (10-24-2017)
Old 10-24-2017, 07:39 AM   #5
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
what would be the speed at 2500 rpm or 2000 rpm with the stock final drive? I've been thinking about this, 6th gear seems all wrong for US speeds. And with the final drive mods it makes it even worse.
why? is offline   Reply With Quote
Old 10-24-2017, 08:05 AM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I wished 6th, and maybe even 5th, was a bit taller for a while as my commute is mostly highway. Though I'm not sure the install time/cost is worth it to me.
Old 10-24-2017, 12:12 PM   #7
tshrey
Drives: Black BRZ
78/3000=x/your target rpm. solve for x.
At 2000 rpm you would be going 52, etc
tshrey is offline   Reply With Quote
The Following User Says Thank You to tshrey For This Useful Post:
why? (10-24-2017)
Old 10-24-2017, 03:19 PM   #8
BRX
BRX's Avatar
Drives: Toyota GT86
I posted on the other thread somehow but anyway, I'm interested in a taller 6th gear or even a whole gear set. But I doubt we'll get 28 other people committed.
Sent from my Pixel XL using Tapatalk
BRX is offline   Reply With Quote
Old 10-24-2017, 04:43 PM   #9
why?
why?'s Avatar
Drives: series.blue
oh ouch, I remember those. I guess there is a reason I have a worthless non-math degree and not something actually useful.
Old 11-09-2018, 06:41 PM   #10
racer1600
Drives: 2013 FRS
Was there any other movement on this product? It would be awesome to get a taller 6th gear.
Sent from my Moto Z (2) using Tapatalk
racer1600 is offline   Reply With Quote
Old 11-09-2018, 07:30 PM   #11
MrDinkleman
Drives: 2016 Oceanic, "base" model
Hmmm... first time I've seen this thread.
How is the quality/durability (based on experiences with shorter gears)?
I've been casually looking for an M85, IS300 LSD rear end to lower my highway RPMs. But this would affect all gears and the speedo.
A taller 6th gear is better approach. For $360, I'm in.
MrDinkleman is offline   Reply With Quote
The Following User Says Thank You to MrDinkleman For This Useful Post:
jcw99 (11-16-2018)
Old 11-09-2018, 07:51 PM   #12
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
The speedo is off the wheel sensor. The only thing that affects it is tire size.
Old 11-09-2018, 09:13 PM   #13
MrDinkleman
Oh, okay. So if this final gear thing dies, I can still go the M85 route although I would still prefer just a taller OD...
Thanks
86Tony (04-25-2019)
Old 11-09-2018, 09:26 PM   #14
x808drifter
LMGTFY
Yep.
Change all the gears you want.
The speedo should read correct if the tire size is the same.
Taller 6th gear? tshrey Engine, Exhaust, Transmission 6 10-24-2017 06:09 AM
Do Automatics have Taller Gears ItzYaBoyBugZ Scion FR-S / Toyota 86 GT86 General Forum 19 05-31-2015 01:42 PM
taller final drive ratio SuperDave Engine, Exhaust, Transmission 17 10-26-2014 04:37 PM
Anyone running taller tires? cactus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-04-2014 04:22 AM
Would a taller / larger oil filter improve oil cooling? brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 05-14-2013 04:18 AM
