Old 10-10-2017, 01:44 PM   #1
Speedy000
Drives: Raven FR-S
Front suspension or steering rack noise?
I’ve read a post about the steering rack coming loose but no videos or other info can someone help me out. I can’t figure out what is making this noise.
Nikon Squad D800
www.flickr.com/speedy000
Speedy000 is offline   Reply With Quote
Old 10-26-2017, 05:14 AM   #2
Alpha_noob
Alpha_noob's Avatar
Drives: Toyota Gt86
Hi Speedy
Do you have coilovers installed on your car?
There's no point in owning an 86 when you like to sell your cars at low mileage
Alpha_noob is offline   Reply With Quote
Old 10-26-2017, 12:40 PM   #3
humfrz
Back-in-the-day, I would guess that the worm gear on the steering rack needed to be tightened down or a ball joint on a steering arm was wore out or a wheel was loose.
Today, I have no idea, but if it were my car, I'd take it into a shop and have it looked at.
Big help ....... huh .....
humfrz
Old 10-26-2017, 04:17 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Originally Posted by Alpha_noob View Post
Hi Speedy
My guess too, maybe the end links?
Old 10-31-2017, 08:20 AM   #5
Alpha_noob
Alpha_noob's Avatar
Drives: Toyota Gt86
I'm thinking it's the end links, or link arms (same thing). that's probably rubbing against the body or are just creaking.
Old 12-22-2017, 10:46 PM   #6
Speedy000
Drives: Raven FR-S
Eh bad steering rack. Passenger side was F*cked.
Problem solved back to normal now.
Nikon Squad D800
The Following 2 Users Say Thank You to Speedy000 For This Useful Post:
norcalpb (02-19-2021), Tcoat (12-22-2017)
Old 02-19-2021, 11:59 AM   #7
DoubleV
Drives: 2013 Toyota GT86
Hi there, I have the same issue..
What was the fix? Did you get it repaired or did you buy a new steering rack?
DoubleV is offline   Reply With Quote
Old 02-19-2021, 12:56 PM   #8
sato
sato's Avatar
Drives: Dodge Patitas
Check end links (sway bar bushings first $10 ea, 2x)
Old 02-19-2021, 04:21 PM   #9
norcalpb
norcalpb's Avatar
Do you have any pictures of the bad steering rack? I'm at 170k miles and have replaced the outer tie rods, but still have a weird clunking noise. Only happens at low speeds which I'm thinking was a symptom of yours as well.
Old 02-19-2021, 04:35 PM   #10
ermax
ermax's Avatar
Don’t rule out the EPS coupler. It creates a rattle/clunking at low speeds. Road reflectors at 10mph for example. I have a DIY thread on fixing this issue for ~$10. This issue seems more common in Russia, Philippines, MENA, etc where crappy roads are more common.
https://www.ft86club.com/forums/showthread.php?t=133606
The Following 2 Users Say Thank You to ermax For This Useful Post:
norcalpb (02-19-2021), Ultramaroon (02-19-2021)
Old 02-19-2021, 05:22 PM   #11
norcalpb
norcalpb's Avatar
I’ve heard the EPS rattle on a couple threads and mine happens just turning the wheel at less than 5mph. I can drive on bumpy roads going straight and everything is silent.
Old 03-18-2021, 09:13 PM   #12
sato
sato's Avatar
Well, you can still check it. It's just a b#tch to loosen and lower.
Sent from my Pixel 3 using Tapatalk
Old 03-24-2021, 07:37 AM   #13
DoubleV
Had the same issue. Also on bad condition roads there was a similar noise to suspension issues.
New steering rack and alignment fixed it
Old 03-24-2021, 08:35 PM   #14
ermax
ermax's Avatar
Did the new rack include the EPS unit? If so, I wouldn’t be surprised if it was only the coupler that was bad.
Steering rack options? Sleepless Tracking / Autocross / HPDE / Drifting 20 04-28-2022 10:57 AM
FS: OEM Steering Rack MicheleAbbate Brakes, Suspension, Chassis 0 04-18-2016 02:51 PM
creaking noise front end of suspension gtzany Scion FR-S / Toyota 86 GT86 General Forum 5 12-10-2014 01:36 PM
Steering rack diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-07-2014 12:12 AM
Unknown Front End Suspension noise RedFRS4me Issues | Warranty | Recalls / TSB 5 03-04-2014 04:57 AM
