Old 05-06-2017, 11:21 PM   #1
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Steering rack options?
Is there a steering rack that fixes the inconsistent boost issues at the track?
Sleepless is offline   Reply With Quote
Old 05-09-2017, 03:01 PM   #2
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
How bad is it? I found too much caster make it horrible and the power steering turns on and off. I still get it every now and then without additional caster but it's not all the time.
Element Tuning is offline   Reply With Quote
Old 05-09-2017, 03:31 PM   #3
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
I've has the power steering cut out for a split second during regular driving conditions and even in parking lots. Has happened twice in like the past month. Feels really unnerving. I believe I'm on stock alignment settings. Interested to hear if there is a solution to this.
ApexEight is offline   Reply With Quote
Old 05-09-2017, 03:37 PM   #4
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
On sticky Trofeo Rs its multiple turns per lap at the Ridge Motorsports Park!
I can live with it, but sure wish I didn't have to.
What is your caster at?
Old 05-09-2017, 03:40 PM   #5
Element Tuning
I can live with it, but sure which I didn't have to.
Oh I had a huge problem with shutting off under trail braking (at least 3 turns a lap). It does make it hard to drive a consistent line when you go from barely holding the whee to straight up man handling it! I just run OEM caster now. It has been dramatically reduced but on occasion I still get it.
The Following 2 Users Say Thank You to Element Tuning For This Useful Post:
Pat (05-09-2017), Sleepless (05-09-2017)
Old 05-09-2017, 05:20 PM   #6
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Yes, trail braking and highly cambered turns!
I thought I'd read that the new cars don't have the problem so I was hoping some might have tried changing to the newer rack, if indeed they are different.
Old 05-09-2017, 05:59 PM   #7
strat61caster
strat61caster's Avatar
It has less to do with the rack and more to do with the power steering, iirc speculation was that it was hot and/or overloaded shutting down to prevent damage to the unit.
If you get under the car the rack is just a straight rack and pinion, the power assist lives behind the dashboard connecting to the steering wheel shaft before it enters the steering rack. If there's an improved unit it'll be that.
Steering shaft and power steering unit:
Steering rack:
Changing the rack itself won't help the problem, maybe if you change the ratio that could lighten the load on the EPS, but you'll have lighter steering feel and require more steering input to get the wheel turned the same amount. And no guarantee the power steering system will coordinate happily with the new ratio, it could go haywire.
Good info out of Element Tuning that increased caster worsens the effect which feeds into the overloading/overheating theory. Maybe that was known before but I don't recall.
ineedyourdiddly
Old 05-09-2017, 06:03 PM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Holy crap no way! It's actually a manual rack? Does this mean we can do an easy PS delete?
Old 05-09-2017, 06:27 PM   #9
strat61caster
Hypothetically, yes. I don't know what it does to the traction control system as a whole though, you might lose ABS, there have been a couple threads on it but I don't recall anything conclusive.
ineedyourdiddly
Old 05-09-2017, 06:45 PM   #10
OND
OND's Avatar
Drives: 2023 BRZ
How about reducing electric assist, so that the motor doesn't overheat? Sounds so doable...
OND is offline   Reply With Quote
Old 05-09-2017, 07:44 PM   #11
tony-brz
tony-brz's Avatar
Drives: '17 BRZ PP
Thought I'd post this. The power steering definitely has overheating protection. This is from the my 2017 BRZ manual:
tony-brz is offline   Reply With Quote
The Following User Says Thank You to tony-brz For This Useful Post:
strat61caster (05-09-2017)
Old 05-10-2017, 09:21 AM   #12
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Sounds like adding heatsinks and/or a small fan might help.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 05-10-2017, 11:43 AM   #13
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
For me, it's not heat-related. I can make it happen in the first corner on a cold day and it is consistent throughout a 30 minute session. It's purely load related. My guess is that it reduces the assist to prevent overheating once it detects a heavy load.
I'd rather set it to reduced-assist full time when on the track so it is consistent. I wonder if it is a closed system or if it is controlled by the ECU. If the latter, maybe Beastronix could add a reduced-assist mode to the 86nanny?
[EDIT: I've contacted Beastronix if they can do this. Told them I'd pay $200 for such a feature; easily. Let them know if you are also interested and how much it is worth to you. Even if it isn't ECU controlled, I bet they can figure out how to put a manual switch directly to the assist controller! Fingers crossed...]
The Following User Says Thank You to Sleepless For This Useful Post:
Jonsey (05-10-2017)
Old 05-10-2017, 12:27 PM   #14
Yoshoobaroo
TRACKBREAD
I'd rather set it to recuced-assist full time when on the track so it is consistent. I wonder if it is a closed system or if it is controlled by the ECU. If the latter, maybe Beastronix could add a reduced-assist mode to the 86nanny?
What happens if you pull the PS fuse?
FS: OEM Steering Rack MicheleAbbate Brakes, Suspension, Chassis 0 04-18-2016 02:51 PM
Cusco steering rack stay olsonpg Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-27-2015 07:35 PM
TiC steering rack bushings review mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-21-2014 12:43 PM
Steering Rack Play FR Sports CANADA 1 06-04-2014 09:00 PM
Steering rack diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-07-2014 12:12 AM
