Old 10-09-2017, 09:26 PM   #1
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Key fob opens doors but keyless entry not working.
I don’t know what is going on. I was evacuating the Santa Rosa area because of the fires so we are packing the car then there is a loud buzzer or sustained beep as I shut the trunk. My fob opens the doors but the keyless entey doesn’t work, nor will the rear trunk open. The key fob can open and lock the doors but they don’t sense when I’m near. Everything else is normal. The only thing is the car does a loud beep as I shut the trunk. I was thinking maybe it is because the rear seats are down but I don’t know and I can’t test it now.
Old 10-09-2017, 10:10 PM   #2
winstonscifi
winstonscifi's Avatar
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
Is the button in the trunk pushed in? That won't let you open the trunk with the remote or with the button on the dashboard. Look in the trunk on the left side - there is a little button there. Your luggage might have shifted and pushed in the button
winstonscifi is offline   Reply With Quote
Old 10-09-2017, 11:52 PM   #3
Irace86.2.0
It’s not the button. That’s what I thought too. I tried that. If I push it then I can’t open the teunk with the fob—only with the key. If I push it again then I gain fob access but not keyless fob access with the button on the trunk.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
winstonscifi (10-10-2017)
Old 10-10-2017, 12:17 PM   #4
Impureclient
Drives: 2015 FR-S
Seats down don't matter so you can scratch that. Maybe need a new battery for keyfob?
Impureclient is offline   Reply With Quote
Old 10-10-2017, 12:25 PM   #5
humfrz
Hi Irace86.2.0, I hope you got away from those fires!
Hopefully you didn't have any property damaged.
As far as your fob not working properly, I suggest the obvious ...... replace the battery ....... just to eliminate the possibility that it is weak.
Next, try your other fob (making sure it's battery is good in it).
Stay safe!
humfrz
Irace86.2.0 (10-11-2017)
Old 10-10-2017, 12:45 PM   #6
jasonojordan
Drives: 2013 satin white brz limited
I had some weird gremlins like this with my 2013. After the 1st year of ownership I had issues with the range on the fob. I would have to be damn near touching the car before the fob would unlock the doors. Sometimes the car would not register the key to just pull on the handle and unlock the door and sometimes the car would not start because it was not sensing the fob. Tried a ton of different stuff to fix it and nothing did. Last winter instead of using a battery tender and leaving everything hooked up I unhooked the battery and just put the tender on the battery and let the car sit with no battery hooked up for 4-5 months. This spring hooked everything back up and the fob has worked as intended since. Not sure if this will help you or not but something maybe worth a try.
jasonojordan is offline   Reply With Quote
The Following User Says Thank You to jasonojordan For This Useful Post:
Old 10-11-2017, 10:04 AM   #7
Irace86.2.0
I want to thank everyone for their input. It just dawned on me that my extra fob is in my file folder/cabinet thing packed in the back of the car. During the evacuation I just threw things in the back and totally forgot. I can’t test it right now because I work at the hospital, the only one open in Santa Rosa at the moment, but I bet the extra fob in there is cancelling the keyless entry for my fob with my keys. Ill test it tonight.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
humfrz (10-11-2017), Tcoat (10-11-2017)
Old 10-11-2017, 10:21 AM   #8
Yep. That would do it.
Old 10-11-2017, 10:46 AM   #9
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
I gotta learn to not keep my mouth shut for fear of being wrong, but this was my first thought. Same thing happened to me when I first got the car, extra fob went in my backpack, and into the truck, making the car beep at me when I try to lock it and the key-less didn't lock the car.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following User Says Thank You to yelsew For This Useful Post:
Old 10-11-2017, 11:21 AM   #10
I can teach you!
humfrz (10-11-2017), Irace86.2.0 (10-11-2017), yelsew (10-11-2017)
Old 10-11-2017, 12:30 PM   #11
humfrz
Hey, most of the rest of us are masters at that .......
humfrz
Tcoat (10-11-2017), yelsew (10-11-2017)
Old 10-11-2017, 11:17 PM   #12
Irace86.2.0
I pulled the key fob from the rest of the items in the trunk. Just to satisfy the curious, that fixed it.
humfrz (10-12-2017), Tcoat (10-12-2017)
Old 10-12-2017, 07:08 AM   #13
BRZnut
Drives: BRZ DGM Limited
good to know. Sorry to see what is going on in your area.
The Following User Says Thank You to BRZnut For This Useful Post:
Irace86.2.0 (10-12-2017)
Old 10-12-2017, 11:02 AM   #14
Impureclient
Drives: 2015 FR-S
humfrz
Best part of the internet. You just get to say a bunch of stuff and something in there will be right sooner or later.
And the stuff that was wrong, you just go back and edit it out. Before my low/dead battery answer, I wrote he should try pushing a banana down in the gas tank and let all the air out the tires.
The Following User Says Thank You to Impureclient For This Useful Post:
humfrz (10-12-2017)
Passive/Keyless entry not working zedthebrz BRZ First-Gen (2012+) — General Topics 14 02-23-2017 08:43 PM
Keyless Entry not working! Frs x3 Scion FR-S / Toyota 86 GT86 General Forum 16 10-20-2015 04:10 PM
keyless entry not working ninjasaurusrex Scion FR-S / Toyota 86 GT86 General Forum 0 06-06-2014 09:08 AM
Do we really have keyless entry? ZackZ Scion FR-S / Toyota 86 GT86 General Forum 4 10-22-2013 10:04 PM
Keyless Entry Delay/Not Working Dezoris Issues | Warranty | Recalls / TSB 0 11-02-2012 06:57 PM
