Old 10-16-2015, 09:53 PM   #1
Frs x3
Likes it in the rear
Frs x3's Avatar
Drives: RS 1.0
Keyless Entry not working!
Hi forum, I took my car into the shop to fix some dents on my driver side door. I got it back and the keyless entry isn't working! The passenger side locks and unlocks fine with my hand hovering over the designated lock /unlock areas but the driver side doesn't respond to anything. Is there a way to re sync the fob?
I'm going to probably end up just taking it back Monday but I'm hoping I can remedy the issue myself.
Thanks in advance
Frs x3 is offline   Reply With Quote
Old 10-16-2015, 10:14 PM   #2
They may have unhooked something in the door in which case you would have to pull it apart to check. An easy check to see if just a electronic issue would be too try unhooking the battery for a couple of minutes. If it is just a BCM issue that could reset it.
Old 10-17-2015, 12:24 AM   #3
Frs x3
Frs x3's Avatar
Drives: RS 1.0
Thanks for the advice. I tried disconnecting th battery for a few minutes but no luck :/ my car is due for an oil change. If I take it in tomorrow and mention the issue would the dealership attempt to fix? Car is under warranty by the way.
Old 10-17-2015, 01:06 AM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Thanks in advance
Does the lock still lock the door? The wire that attaches to the lock could of been undone when they did the PDR.
N1rve
Old 10-17-2015, 01:07 AM   #5
If the body shop screwed something up then warranty will not cover it. Unless of course you have one of the better dealers that will just fix it and send you on your way.
Old 10-17-2015, 01:12 AM   #6
Frs x3
Frs x3's Avatar
Drives: RS 1.0
Yeah lock still works
Old 10-17-2015, 08:13 PM   #7
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
The BCM in our cars is so damn finnicky it's kind of annoying I see so many people have issues after installing LEDs or HIDs and everything just goes bad after that even though its a high quality kit.
Old 10-17-2015, 08:42 PM   #8
The more they hook up through it the more chance of something going wrong. I can never understand why tails or manual op only headlights even need to run through it.
It is like they want to computerize everything whether it needs to be or not. That sometimes goes dreadfully wrong.
Old 10-17-2015, 09:14 PM   #9
FRSBRZGT86FAN
CANBUS HID are key on this car then lol
Old 10-18-2015, 03:18 PM   #10
Frs x3
Frs x3's Avatar
Drives: RS 1.0
Well took it to the dealer yesterday for the oil change and mentioned the issue. They say it'll cost 375 just to diagnose it.
Old 10-18-2015, 03:38 PM   #11
N1rve
N1rve's Avatar
I'd take it back to that body shop and ask them to fix it. How did they PDR the door? Did they jam something to split open the window seal and then put a pry rod down there and push the dent out?
N1rve
Old 10-18-2015, 03:39 PM   #12
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
The first logical thing to do, return the car to the shop which did the bodywork.
Other option is to simply fix the problem yourself.
I agree with Tcoat. "They may have unhooked something in the door in which case you would have to pull it apart to check."
That something could be either electrical or mechanical.
Remove door panel and look at all connections within the door. Attached both a video and a link to pics from this site:
[ame="https://www.youtube.com/watch?v=v-oPkoXfFeY"]2013+ Scion FR-S door panel removal, with Tito Brylle - YouTube[/ame]
http://www.ft86club.com/forums/showthread.php?t=12520
ToySub1946 is offline   Reply With Quote
Old 10-18-2015, 03:47 PM   #13
Frs x3
Frs x3's Avatar
Drives: RS 1.0
Yeah definitely taking it back to the body shop. It had some pretty large dents on the driver door. There's some welding on the door as well so I know they disassembled it. Goin to bring it into the shop to address the issues on the morning
Old 10-18-2015, 04:11 PM   #14
ToySub1946
ToySub1946's Avatar
Most likely that bodyshop didn't want to mess with taking the large dents out, so they instead welded onto the door, an entire new door shell (door skin).
keyless entry not working ninjasaurusrex Scion FR-S / Toyota 86 GT86 General Forum 0 06-06-2014 09:08 AM
Keyless Entry Upgrade Tr1huynh Electronics | Audio | NAV | Infotainment 3 02-24-2014 08:07 PM
Do we really have keyless entry? ZackZ Scion FR-S / Toyota 86 GT86 General Forum 4 10-22-2013 10:04 PM
Keyless Entry Delay/Not Working Dezoris Issues | Warranty | Recalls / TSB 0 11-02-2012 06:57 PM
BRZ Keyless entry? Motopythons CANADA 7 06-03-2012 05:56 PM
