| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: Silver ‘17 BRZ
Passive/Keyless entry not working
When I walk up to my car and put my hand through the door handle it does not unlock and when I try to lock it by using the little pad on the door handle it just beeps and doesn't do anything, but when I walk up to my trunk and try to open it, it works, it seems to just not work with the doors, I can still push the button to unlock and lock it but I cant just walk up to it, plz help and thanks
Drives: 13 BRZ (sold) 20 BRZ TS (sold)
key fob battery dying? if that hasn't been changed recently that'd be my expectation.
Drives: '17 CWP w/ PP
I believe you have a '17, I would read the manual and make sure that all your keyless settings are right. It could be from the factory, port, or dealer it my not be set up. If that doesnt work, then right to the dealer you go
It's probably your battery, they have them at Radio Shack for like $3. The trunk sensor is probably closer to you when you open the trunk, than the door sensor is when you're opening the doors?
Idk worth a shot, even if it's just to clean the inside of the fob. |
#5 | |
Drives: 10 Series FR-S #207
Is your other key inside the cabin? This kind of sounds like what the car becahves like in that situation.... |
Replace the battery on the key fob. Happened to mine already.
If the battery is completely dead, use the little key to open the door, then quickly jump in and hold the fob next to the press to start button and fire up the engine in order to shut the alarm. The alarm will be on even if you manually lock the door. |
Drives: hyper blue
for entertainment, the owners manual has a list of places not to keep your keyless start keys; near TVs, personal computers, cellular phones, cordless phones and battery chargers, recharging cellular phones or cordless phones, glass top ranges and last but not least table lamps.
A.K.A. Starlord
Drives: 2015 Series.Blue
Just a little quirk I recently discovered: I was having issues with my fob being detected inside the vehicle. The car would unlock and lock just fine, but once I sat down, it wouldn't let me start because it couldn't detect the fob (yellow light on the dash) until I took it out of my pocket and waved it around. At first it was intermittent, but it slowly became more consistent. I replaced the battery in the fob, to no avail.
Fast forward one month, and my car is at the dealership for a new transmission, and when they went to work on the car, the battery was COMPLETELY dead, and it wouldn't start. They charged it, and it was fine again, but I noticed the car was getting a bit more sluggish turning over when starting. That's when I made the connection. My key fob only wouldn't be detected by the car after the car had been sitting for a while (AKA, when the battery hadn't been recently topped-off). So I replaced my CAR battery, and not only does my car more energetically now, but it detects the key fob without any issues, and has for weeks without a single hiccup. So it seems like even a slightly weak battery, while still plenty strong enough to start the car, can cause the keyless entry antennae in the car to lose their sensitivity.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
Drives: BRZ DGM Limited
Interesting...another odd thing that I noticed is that my LEDs would flicker when car was running at idle. Replaced the battery with a Red Top and the flicker resolved.
#10 |
#11 |
I have a '13 it's just that my Valenti taillights Mae it look like that, lol
#12 |
#13 |
So it wasn't the key battery, any other ideas?
#14 |
Drives: 2015 BRZ Sport Tech CWP
Did you try and use your spare key instead of the key you normally use?
If it works, your main key is defective. If the problem persists, the problem is car related. Try the passenger door handle. If the problem is still there, maybe you car battery has a low voltage.
| Keyless Entry not working! | Frs x3 | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 10-20-2015 04:10 PM |
| keyless entry not working | ninjasaurusrex | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 06-06-2014 09:08 AM |
| Do we really have keyless entry? | ZackZ | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 10-22-2013 10:04 PM |
| Keyless Entry Delay/Not Working | Dezoris | Issues | Warranty | Recalls / TSB | 0 | 11-02-2012 06:57 PM |
| BRZ Keyless entry? | Motopythons | CANADA | 7 | 06-03-2012 05:56 PM |
