Drives: gt86
gauge electric installation
Hello! I have a pressure gauge. It has the possibility to program low pressure alarm, but only stays in memory if it is connected to 12v permanent positive ....
Has anyone made this installation in our car with a start button? not with a starter key. Can you explain which cable you use for permanent 12v? |
#2 | |
Drives: Car Collector
Typically any device will state in it's documentation what it's amperage draw is. If your gauge draws very little, you have both constant and switched with ignition 12V leads that are easy to identify and tie into via the stereo harness. Again, it will depend on how much your gauge draws though. |
Drives: gt86
Yes, two positives, and the light only comes on when contacting, but it does not keep the memory ..... they are prosporst gauges, and I have to regulate the low pressure warning every time I turn the car off
Fuse Taps
For your constant I would use a piggy back / fuse tap which allows you to tap into power at the fuse box. You will just need to use a multimeter or simple 12 volt electriial tester to determine which fuses have constant power when the ignition is off. You will find several so I would pick one which does not control something crucial for vehicle operation. Perhaps something simple as dome light.
This video should walk you through it. If after viewing it you still do not feel comfortable doing it yourself, search out a shop or friend who understand basic automotive wiring. [ame="https://www.youtube.com/watch?v=8omZ545Cw1U"]https://www.youtube.com/watch?v=8omZ545Cw1U[/ame] |
| AEM Oil temperature gauge and pressure gauge with pods. | mtsound | Engine, Exhaust, Bolt-Ons | 2 | 08-24-2017 12:55 PM |
| P3Cars vent gauge installation | ntaphse | Electronics | Audio | NAV | Infotainment | 54 | 03-01-2016 05:32 PM |
| Oil Temp Gauge installation | BRZ NA | BRZ First-Gen (2012+) — General Topics | 35 | 08-17-2015 01:59 PM |
| Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review | Tye300 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 05-22-2015 12:48 PM |
| Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) — General Topics | 40 | 08-19-2012 04:29 PM |
