Old 09-27-2013, 03:28 PM   #1
ntaphse
Drives: beater
P3Cars vent gauge installation
I didn't see much info on this so I snapped a few pics while I installed my gauge yesterday. I did the install on my lunch break in the parking lot, it only took 10 minutes!
I got it here: http://www.p3cars.com/subaru-brz-sci...s-toyota-ft86/
Here's what comes in the box if you order the pre-installed gauge.
Remove the vent by prying around the edge. I used a plastic panel tool from Harbor Freight. It pops out easily.
Sneak the cable down behind the dash panel.
Snap the vent into place. The skinny side goes up.
Open the control box and cables. The control box came in a static-proof bag!
Plug into the OBD port and make the rest of your connections with the cables loose on the floor. I'm not using any of the aux channels yet so I just zip-tied these to the main cable.
Last I zip-tied everything up out of sight under the dash. It was too dark under the dash to get a pic, but it's easy. I started the car and the gauge was ready to go! This is the water temp screen.
It monitors AFR's too (and a lot more). Can't wait to get the Innovate supercharger and use this to monitor boost.
Pretty damn sweet if you ask me, I really like the integrated approach. I have an old ScanGauge and I remember guys using velcro to stick the on the dash or column. This is sooooo much nicer looking. The read-out matches the factory orange color on my gauge cluster too.
ntaphse is offline   Reply With Quote
The Following 12 Users Say Thank You to ntaphse For This Useful Post:
Anthonytpt (11-15-2013), ill86 (11-04-2013), JPxM0Dz (10-25-2013), Lonewolf (11-16-2013), muffinz (09-27-2013), MyEvilMonkeys (05-28-2014), n2oinferno (10-03-2013), normancw (10-03-2013), PoorMansRacing (12-20-2013), RallySport Direct (09-27-2013), shiro (11-15-2013), SocalMonsta (03-19-2015)
Old 09-27-2013, 04:54 PM   #2
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Thanks for this post. I've had my eye on this gauge for awhile now. Super clean install!
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 09-27-2013, 05:01 PM   #3
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Sweet functional add on indeed. I'll be doing this as well for FI application later on simply makes sense!!
P.S.
There are options on their site, yours is pre installed housing selection??
Old 09-27-2013, 05:44 PM   #4
p00mba
p00mba's Avatar
Drives: FR-S :)
love it looks awsome, i may need to look into somthing like this....
p00mba is offline   Reply With Quote
Old 09-27-2013, 06:36 PM   #5
White64Goat
Did you buy just the gauge or the whole vent? Do you think installing the gauge in your own vent would be easy? (Saves some $ if you do)
Old 09-27-2013, 07:04 PM   #6
ntaphse
Drives: beater
P.S.
Yes I got the pre-installed selection, you can buy just the gauge and install it yourself to save some money. I saw a how-to somewhere, it looked pretty easy.
Old 09-27-2013, 09:20 PM   #7
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Auto-Dimming
I didn't get a chance to tidy up my install but essentially the wire I labeled as the positive (+) trigger parking lights is where you want to tap into (i.e. military splice) with the green wire from the P3Cars gauge.
Once done, go into the gauge configuration settings and change the dimmer setting to "On.A" then hold the right button to save the option (you gauge will then reset).
Now when you turn on the lights, or your lights come on automatically, the gauge will dim.
Bright
Dim
Video showing the transition between bright and dim
View P3Cars Gauge Video
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following 2 Users Say Thank You to ecko04 For This Useful Post:
Jimmy45brz (07-18-2014), ntaphse (10-03-2013)
Old 10-02-2013, 11:31 PM   #8
B2FiNiTY
JDM JUNKY
B2FiNiTY's Avatar
Drives: NSX
nice install!
B2FiNiTY is offline   Reply With Quote
Old 10-25-2013, 12:30 PM   #9
brn12345
brn12345's Avatar
Installed my P3 Cars Gauge today. Took 15min to install with everything tie wrapped neatly. Absolutely love it.
brn12345 is offline   Reply With Quote
Old 10-25-2013, 12:43 PM   #10
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Yeah I need to order this soon...
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 11-15-2013, 03:46 AM   #11
OICU812
Just a dude
OICU812's Avatar
Got guage today. Noticed green wire has a pre crimped spade, is this made now to directly plug in somewhere or still need to tap into parking wire for dimmer? If anyone knows I'd sure like to know!
Thx
Old 11-15-2013, 07:26 AM   #12
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Thx
That's how all of them come. There should be spades on the blue and brown auxiliary wires too. You still need to tap.
Old 11-15-2013, 09:11 AM   #13
OICU812
Just a dude
OICU812's Avatar
Ahhh ok wasn't sure on that. The plugs/wires etc you show in pics, are those behind the hood latch release panel lower left? Pretty sure just confirming. I'll need to see if I can find some of those squeeze quick wire taps, pretty sure these wires are around 18 guage by appearance.
Old 11-15-2013, 09:28 AM   #14
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Yes.
Military splicing is the preferred method. I avoid t-taps at all cost
The Following User Says Thank You to ecko04 For This Useful Post:
shiro (11-15-2013)
PTUNING: ATI 60mm Vent Gauge Pod - NEW! ptuning Interior Parts (Incl. Lighting) 0 09-19-2013 03:23 PM
WTB: P3CARS FR-S BRZ Integrated AC Vent Display Gauge GTB/ZR-1 Want-To-Buy Requests 0 09-15-2013 03:43 PM
ATI vent pod for gauge sw20kosh Cosmetic Modification (Interior/Exterior/Lighting) 2 08-30-2013 09:49 AM
Anybody local have a P3Cars vent installed? Pneub Southern California 8 08-14-2013 03:33 AM
