Old 10-08-2017, 10:11 PM   #1
drz400dude
Vented hoods and rain
Looking at options to keep under hood temps down in the summer. I've been looking at CF hoods with vents or just installing vents on my current hood.
It's my daily driver so out sits out in the weather at work, but is garage kept at night. Are there any issues with rain getting into places it shouldn't through the vents? I live in the desert and don't get a whole lot of rain.
Sent from my SAMSUNG-SM-N920A using Tapatalk
drz400dude is offline   Reply With Quote
Old 10-08-2017, 10:37 PM   #2
thatonehoonigan
thatonehoonigan's Avatar
Drives: '16 Halo White FR-S '07 GSX-R600
You'll be perfectly okay with the vents and rain, just be prepared for the engine bay to get dirty real quick lol. But if you are still worried Verus (formerly Velox) makes a Hood Vent Kit that has an optional rain guard and has data to back up the cooling capabilities, and is more cost effective than a CF Hood.
Sent from my SM-G935P using Tapatalk
thatonehoonigan is offline   Reply With Quote
The Following User Says Thank You to thatonehoonigan For This Useful Post:
drz400dude (10-09-2017)
Old 10-09-2017, 12:26 AM   #3
Hags86
Drives: Toyota GTS 86
I live in Melbourne Australia which is renowned for its rainy days. Had a vented CF hood for 4 years. No rain gutters or anything - the water just pours onto the alternator. Not a single problem.
It is parked undecover during the day on weekdays, outside the rest of the time.
Just go for it.
Hags86 is offline   Reply With Quote
The Following User Says Thank You to Hags86 For This Useful Post:
Old 10-09-2017, 02:09 AM   #4
Zero issues.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
drz400dude (10-09-2017), Jyn (10-09-2017), rb6freak (10-10-2017)
Old 10-09-2017, 11:46 AM   #5
RFB
RFB's Avatar
Drives: FRS
Zero issues.
Even with a vent hole near an exposed air filter, as in a Jackson blower kit ?
RFB is offline   Reply With Quote
Old 10-09-2017, 12:15 PM   #6
sachu
Drives: rocketship
I am having the same issue with my Velox hood vents.
RUnning a turbo setup though with a turbo blanket and header wrap on the down pipe.
Seriously considering getting the rain guards or just hard park in the garage on a battery tender till next late April.
Part of me wishes, I had jsut left the stock hood unmolested and just spent on a vented VIS hood so I could switch between the two.
sachu is offline   Reply With Quote
Old 10-09-2017, 12:32 PM   #7
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
For NA, I've ran the tracspec hood vents (the largest designed for this platform) with no issues. It's sat in downpouring rain recently on my trip from Texas to Atlanta for Gridlife and fired right up.
ChinTrackDays ran the tracspec vents as well during pouring rain and constantly sat their track 86 outside with no reported issues.
YMMV for FI. Not sure on how water on running hot parts does.
Jyn is offline   Reply With Quote
Old 10-09-2017, 12:58 PM   #8
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Water cools down engine bay temps more than air will.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
DarkPira7e (06-02-2018)
Old 10-09-2017, 04:18 PM   #9
Unless you're literally dumping buckets of water on the filter, no issues.
Old 10-09-2017, 04:19 PM   #10
water on exhaust/turbo components (in volume) is bad. A mist can cool everything, but that's a different story.
sachu (10-09-2017)
Old 10-09-2017, 08:17 PM   #11
drz400dude
I've seen the Volex kit and was trying to decide between that and a CF hood. My engine bay gets disgusting in the winter anyways because when it does rain it gets fine sand in the puddles and gets splashed into the engine bay.
I have the works kit, so All of my exhaust and turbo components would most likely sit aft or off to the side of any vents, so rain wouldn't directly fall onto the very hot components and cause any issues with thermal stress.
The only thing I was worried about with the verus kit was if the rain guards would fit since my intercooler sits RIGHT below the hood. I guess it would help to have cold rain on the intercooler. Plus this kit seems easier than fitting a new hood, swapping the hardware, installing hood pins.
Thanks for the input everyone.
Old 10-09-2017, 08:24 PM   #12
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
be a baller/internet pimp and buy this hood.
The Following User Says Thank You to chaoskaze For This Useful Post:
brandonblt2 (04-16-2022)
Old 10-12-2017, 05:58 PM   #13
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
Look up the little known cars... mitsubishi evo 1-10 and subaru sti "all generations with a hood scoop".
The evo's take on a lot of water with no issue ever the engine and turbo.
The same goes for the sti and more so for the ones that have aftermarket hoods with both vents and a scoop. Their engine has a similar lay out and they are 100% peachy keen.
So if you overlap examples of an sti engine getting wet with an evo engine that has a modified turbo set up which will take on a bunch of water through its vent hole/holes, you can easily conclude that an FA20 with a turbo located anywhere in the engine bay mixed with water will be be just fine and dandly like lead filled candy.
TachyonBomb is offline   Reply With Quote
Question about CF Hoods... FloridaBRZ BRZ First-Gen (2012+) — General Topics 7 12-28-2014 01:07 AM
Carbon hoods - need help gdrider77 Cosmetic Modification (Interior/Exterior/Lighting) 8 10-09-2014 12:53 AM
Vented hoods and turbos Nothing Forced Induction 176 07-18-2014 03:40 PM
Vented Hoods and Weather? mrdanyo Cosmetic Modification (Interior/Exterior/Lighting) 15 06-26-2014 11:05 PM
FRP Hoods, anyone have experience with them? Brody602 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-07-2014 11:20 PM
