Drives: 2013 Subaru Brz
How meaty can my car get?
So I want to run 18x9.5 all around with a +35 offset. I also plan to get some federal tires that are 245/35/18. The car is also on coil overs so I will be lowering it. Does anyone have this setup(if you do please post pictures)? Will this setup be flush against the fender will I have to do a lot of camber? Will I have any issues with rubbing?
Drives: Panda BRZ
I run 18x9.5 +35 lowered 1" on springs. Tired are stretched 225/40. Fronts are pretty close to rubbing but it clears on full lock turns. If you're on coils, you'll clear just fine. The fronts poke out a bit and as for rears, mine cambered in a bit so the rear is flush while my fronts poke out. Sorry my photos aren't that great but I hope It gives you an idea about the setup
![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my LG-H918 using Tapatalk |
It depends how much you plan on lowering. If you lower it an inch it'll likely poke. You won't have much rubbing issues... only maybe on full lock.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
Drives: FR-S 10 series
IG: @Lucky_FatPat
10 series // TRD x Turbo Build: http://www.ft86club.com/forums/showthread.php?t=79474 |
| Meaty Tire Thread | Jive Turkey | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2552 | 12-28-2025 10:06 AM |
| (HELP) 17x9 RPF1 meaty fitment | Benschneider06 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 02-25-2018 10:45 PM |
| Meaty tires suggestions for 17x8 35? | YamahaR86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 12-04-2015 12:24 PM |
| My Meaty FR-S Build | JarredH | Member's Car Journals | 1 | 06-02-2014 08:10 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
