Old 01-22-2016, 12:37 PM   #1
Benschneider06
Benschneider06's Avatar
Drives: Satin White Pearl Subaru BRZ
Question (HELP) 17x9 RPF1 meaty fitment
If you're here to light me up about a duplicate post, just click away now.
I need some help!
After months searching I found the wheels I want to run on my 2013 BRZ.
I want to run 17x9 RPF1's with a 245/40/17 tire
I currently have Eibach Pro-Kit lowering springs which drop my car 1" in the front and 1" in the rear.
What offset would I need to be able to run this setup with 0 chance of rubbing? Would I have to ditch the springs? I would like to start getting into track days.
Going for this look (this guy is running 17x9 +35 with a 245/40/17 but I'm not sure if he has lowering springs or not. Nor am I sure whether his setup rubs. It also looks like his wheels stick out pretty far.)
Benschneider06 is offline   Reply With Quote
Old 01-22-2016, 12:47 PM   #2
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
+35 is your safest available bet. 17x9 +35 with 235/40 tires barely cleared my stock springs though.
245 would be worse obviously.
KevinK121 is offline   Reply With Quote
Old 01-22-2016, 01:25 PM   #3
Benschneider06
I wonder how this guy has done it, then..
I really like your setup as well.
Old 01-22-2016, 01:26 PM   #4
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
+35 is the way to go on this setup. Can clear BBK and you can dial in some camber without rubbing on stock struts.
And yes, I'll still flame you just a tiny bit, this EXACT question is posed about 150 times on the rpf1 wheel directory. It's a sticky, and there's pages upon pages of pictures, examples on stock suspension, lowering springs, and coilovers.
The bead measurement of the tire can depend slightly on the manufacturer. My NT01's are 235s but the sidewall comes out pretty square. 245/40 is the tire size of choice for most tires, though ive seen 245/45 MPSS work just fine on everything stock. I'm dropped on TRD springs on stock struts. I drive in canyons and track frequently and have no trouble with rubbing.
Toyarzee is offline   Reply With Quote
Old 01-22-2016, 01:27 PM   #5
whataboutbob
AutoX-10/10ths every run
You can run 245/40R17s on 17x9et35s no problem with lowering springs. I did it for some time while autocrossing before I put coilovers on my car. If you run the 17x9et45s it may be a very close fit depending on how much front camber you run.
Build thread:Here
Old 01-22-2016, 01:34 PM   #6
whataboutbob
Here's some shots of mine on springs and with the et35s:
http://www.ft86club.com/forums/showp...5&postcount=53
Build thread:Here
Old 01-22-2016, 01:42 PM   #7
Toyarzee
Shibby!
Toyarzee's Avatar
Originally Posted by Benschneider06 View Post
I need some help!
For your reading pleasure: http://www.ft86club.com/forums/showthread.php?t=15160
Old 01-22-2016, 01:44 PM   #8
Benschneider06
Awesome! Thank you so much.
I think I'm going to go with +35mm because I will be running stock camber.
Old 01-22-2016, 01:45 PM   #9
Benschneider06
Originally Posted by Toyarzee View Post
thanks
Old 01-22-2016, 01:48 PM   #10
Toyarzee
Shibby!
Toyarzee's Avatar
Btw you no longer have "stock" camber if you're lowered on eibach springs.
Old 01-22-2016, 03:24 PM   #11
KevinK121
Miata traitor
KevinK121's Avatar
Thanks.
But yeah, when mine were mounted up I was barely able to run my hand between the spring and the tire. It was too close for my comfort.
Coilovers in and it was just fine
Old 01-22-2016, 04:02 PM   #12
Benschneider06
So I have 17x9 +35mm Enkie RPF1's in my cart with 245/40/17 Pilot Super Sports to wrap them in my cart. My car is lowered 1"
I've someone reassure me it will fit & someone tell me it won't fit without coils...
Anyone want to chime in before I buy a setup that doesn't fit?
Old 01-22-2016, 04:16 PM   #13
KevinK121
Miata traitor
KevinK121's Avatar
Maybe I missed the part about you being lowered but are the springs in the car now, smaller in circumference than the stock ones were?
If significantly, then you should be ok.
Coils are just much smaller around than the stock springs are.
Old 01-22-2016, 04:40 PM   #14
Benschneider06
I'm not sure if they are a smaller diameter. I doubt they're any larger.
Their Eibach Pro-Kit springs AKA TRD Springs
fitment, offset, rubbing, tires, wheels
17x9.5 +15 fitment Matty-T Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-02-2015 06:26 AM
17x9 6UL - FT86 fitment available soon Guillaume Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 02-17-2015 11:54 AM
RPF1 Fitment pf330ci Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-25-2014 10:07 PM
used RPF1 17x9 +35 or new Rota RT5 17x9 +42 Roadcone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-12-2014 01:16 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
