Drives: Sprintex Supercharged FRS
FA20 Club Flex fuel kit
I recently purchased an FA20club flex fuel kit and the kit is supposed to be an easy installation. The kit told me to connect a wire from the ethanol gauge to a certain pin on the ecu. I did this and when I turned the car over the car started freaking out and the rpms were everywhere and the car was really shaking. I then proceeded to lose my key and still cannot find it. I took it to the dealer and the programmer is getting no connection from the ecu. He can't program it cause it's not responding. Does anyone know what I did? Maybe shorted out something in the ecu or disconnected a pin. I have no idea what to do because I have no key to try and start the car. Anything would help!(:
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
All I know is, you picked one of the worst brands to purchase from.
#3 | |
assume you probably connected to Connector A35 pin 20 for evap input. did you remove evap connection ?? else you will have two signals fighting each other. Did you flash flex fuel tune ?? Can you use ecutek to do a query ecu (assuming your using ecutek) or other flash device to talk to ecu. If flash device will talk to ecu then its ok. however you will need key to turn car on. |
#4 | |
#5 | |
Unlikely the ecu is damaged if car started and ran, unlikely the flex connection or tune will interfere with them codong in new key |
| Ernest's Flex-Fuel, FBM Stage 2 Turbo, Built FA20-V161 Driven BRZ - PHOTON | Enalband24 | Member's Car Journals | 78 | 02-04-2020 01:55 PM |
| Fa20 club flex fuel kit | Mr davis | Engine, Exhaust, Transmission | 1 | 09-18-2017 11:26 AM |
| Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System | DeliciousTuning | Software Tuning | 20 | 06-09-2016 06:21 AM |
| Just joined the E85 Flex Fuel and probably 400HP Club! | Synack | Forced Induction | 3 | 03-23-2015 03:51 PM |
| ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! | Visconti | Engine, Exhaust, Transmission | 356 | 05-20-2013 09:36 AM |
