Old 10-06-2017, 12:49 PM   #1
Dennett_
Dennett_'s Avatar
Drives: Sprintex Supercharged FRS
FA20 Club Flex fuel kit
I recently purchased an FA20club flex fuel kit and the kit is supposed to be an easy installation. The kit told me to connect a wire from the ethanol gauge to a certain pin on the ecu. I did this and when I turned the car over the car started freaking out and the rpms were everywhere and the car was really shaking. I then proceeded to lose my key and still cannot find it. I took it to the dealer and the programmer is getting no connection from the ecu. He can't program it cause it's not responding. Does anyone know what I did? Maybe shorted out something in the ecu or disconnected a pin. I have no idea what to do because I have no key to try and start the car. Anything would help!(:
Dennett_ is offline   Reply With Quote
Old 10-07-2017, 01:56 PM   #2
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
All I know is, you picked one of the worst brands to purchase from.
Dr. BRZ is offline   Reply With Quote
Old 10-07-2017, 06:23 PM   #3
steve99
Drives: FT86
assume you probably connected to Connector A35 pin 20 for evap input. did you remove evap connection ?? else you will have two signals fighting each other.
Did you flash flex fuel tune ??
Can you use ecutek to do a query ecu (assuming your using ecutek) or other flash device to talk to ecu. If flash device will talk to ecu then its ok. however you will need key to turn car on.
Old 10-08-2017, 08:42 PM   #4
Dennett_
Dennett_'s Avatar
So I cut the wire that went into the Evap sensor and connected the wire which led to the ethanol analyzer. What do I need to do to disconnect it. I'm gonna take off the flex fuel kit and reconnect the wire to see if the dealer can program the key without the flex fuel kit on but I'm still confused on how to connect the flex fuel kit to the ECU. The instructions I got to install the kit are so bad I didn't really know what to do.
Old 10-09-2017, 06:18 PM   #5
steve99
Drives: FT86
Unlikely the ecu is damaged if car started and ran, unlikely the flex connection or tune will interfere with them codong in new key
Old 10-11-2017, 10:13 PM   #6
Dennett_
Dennett_'s Avatar
I know and they wanted to charge me 400$ just to run a diagnosis on the car
Ernest's Flex-Fuel, FBM Stage 2 Turbo, Built FA20-V161 Driven BRZ - PHOTON Enalband24 Member's Car Journals 78 02-04-2020 01:55 PM
Fa20 club flex fuel kit Mr davis Engine, Exhaust, Transmission 1 09-18-2017 11:26 AM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
Just joined the E85 Flex Fuel and probably 400HP Club! Synack Forced Induction 3 03-23-2015 03:51 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
