Old 09-21-2017, 12:10 PM   #1
IGW
Trying to figure out MAF scaling
I am not sure I even need to scale as I am almost always under 5% LTFT. There are a few times that i go into the low 6's but its my understanding that this can be normal?
I have an INJEN cold air intake that came with the car when i bought it, so going back to stock is not an option.
I am just wanting to run an OFT stage 1 tun for now, and perhaps play around with a the ethonol tune, but I have been told that I can hurt the car if i dont figure out my MAF scaling prior to putting any tunes on the car.
I have two logs I can share if anyone could point me the right direction on how to upload them. One is a very spirited driving session, and the other was my normal daily drive on my way into work.
So i guess i am trying to figure out mostly if i even need to change my MAF scaling prior to putting on a stage one tune, and then if i do, a little help figuring that process out.
Car is a 2013 FR-S
IGW is offline   Reply With Quote
Old 09-21-2017, 12:44 PM   #2
jvincent
jvincent's Avatar
Start with this thread and all the threads in @steve99's signature.
http://www.ft86club.com/forums/showthread.php?t=71157
Old 09-21-2017, 12:56 PM   #3
IGW
None of that really applies to the questions I asked. I appreciate the attempt though.
I have also been through the MAF scaling thread, which doesn't directly address the questions I asked either.
Old 09-21-2017, 01:01 PM   #4
IGW
My LTFT's are averaging under 3. it occasionally bumps up to the low 6's with what i understand to be heavy throttle use, but then drops back down. I do not have a check engine light on either.
Its my understanding that this is well within the accepted range, but i am wanting to comfirm that this is the case and i am OK to add the stage one tune.
Old 09-21-2017, 02:37 PM   #5
jvincent
jvincent's Avatar
Which specific question wasn't answered? Depending on what tune you flash it will likely have a new MAF scale anyway.
Old 09-21-2017, 02:48 PM   #6
IGW
I would like to post my logs, so they can be viewed, to know for sure that its safe to flash stage one w/out rescaling the MAF. Ill collect data logs from there and try and tweak it but figuring that out right now is proving to be very difficult.
I am also not sure that my logs are showing a need to even rescale the MAF to begin with.
Old 09-21-2017, 03:01 PM   #7
jvincent
jvincent's Avatar
I thought in one of @steve99's links he talked about how to post logs.
Everyone here posts them on datazap. http://datazap.me
Register for an account and then upload the logs. If you look in the tuning sub-forum you'll find some examples.
Old 09-21-2017, 03:23 PM   #8
IGW
https://datazap.me/u/igw/log-1506021668?log=0&data=1-13
https://datazap.me/u/igw/log-1506021448?log=0&data=1-13
Old 09-21-2017, 05:28 PM   #9
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
If you're primarily looking at LTFT instead of AFR, then you totally and utterly missed the point making any changes in the first place (that goes for everyone else too). And we have to assume this is true because you only mention LTFT in your post and not AFR.
Answer: it's pointless waste of time to start on the stock tune.
Old 09-21-2017, 05:44 PM   #10
IGW
Correct, I am struggling to comprehend everything that is at play and what I need to do.
That was what I thought the benefits of the OFT were, that it was plug and play and get the tune, and allow myself to run E85 at times also.
If its safe to put on stage one then do data logging that would save the whole step of doing it on the stock tune.
Then again, perhaps i am just daydreaming that i will be able to get past this learning curve all together, and in a safe mannor. That 250 bucks for the custom tune seem a whole lot more appealing now.
Is it unsafe to run stage one?
Old 09-21-2017, 05:48 PM   #11
Vin
Vin's Avatar
Drives: 2012 GT86 EU-spec
Read the guide mentioned above, it will tell you what parameters to log and how to drive for a good log (3rd gear pulls which are missing from your current logs), flash the tune, take a log and the data will tell you what you need to know. Ive already know of two guys that went back to stock intake afterwards (I'm one of them) so be prepared, data doesn't lie :p
Vin is offline   Reply With Quote
Old 09-21-2017, 05:54 PM   #12
IGW
If i find a way to cheaply and easily go to a stock intake, i would. The car came used with this intake so i am stuck with it.
I guess i am still at the point where i need hand holding. you are the second person to tell me i need to log certain things, but am not sure how to make that change.
Old 09-21-2017, 06:18 PM   #13
Vin
Vin's Avatar
I'm sure youll find someone willing to swap, maybe even with cash on their side. But first take that log on the current intake, maybe it's not that bad. My friend had a stage 2 tune with kn intake, that one was really worse, ltft values looked fine but it ran leaner than the sensors could measure (also on stock tune)
Watch the video's from Shiv too, it will teach you pretty much everything.
Old 09-21-2017, 06:22 PM   #14
IGW
Do you mean take the 3rd gear pull log? As in from a stop start out in 3rd gear and run it up as hard as i can?
I cant figure it out... Need help snapplepat Forced Induction 9 02-20-2017 10:22 AM
3 BAR Map Sensor Scaling tonytduc Forced Induction 9 06-24-2016 02:24 PM
What MAF scaling says about your intake BuBlake Software Tuning 27 12-09-2014 05:01 AM
Go figure! Pdxc43 Northwest 3 01-26-2013 09:03 PM
