Old 09-19-2017, 03:56 PM   #1
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
Broken/Free-spinning Wheel Stud
So I have a pre-owned 2013 Scion FRS. Recently, I replaced the Aftermarket Wheel it came with to 18x9.5 Wedssports. Unknowingly, the previous owner replaced the OEM stud with an extended wheel Stud. So, I used an OEM sized Lugnut. As we were putting on the lugnuts, we realized that there's a gap. So as we used the drill and torque wrench to tighten the nut, the wheel stud came off from the back/hub. Now, the stud is free spinning with the wheel and lugnut on.
We tried numerous ways to untorque/remove the lugnut from the stud, but it would not come off. We resided with drilling the Lugnut and the wheel stud. We already went through a lot of drill bits, and don't have much time to finish it. We're only about 1/4th of the way through the stud.
Do you guys know another way to solve this problem? To makes things worse, I have a screw on tire. It's pretty much a ticking time bomb right now...
Thank you guys in advance for answering this question!
Exrald is offline   Reply With Quote
Old 09-19-2017, 04:18 PM   #2
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Remove the other 4 lug nuts, and use the wheel as leverage to snap the stud.
That stud is already toasted, DON'T try and reuse it.
It works for wheel thieves, it'll work for you.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 09-19-2017, 04:30 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Studs are easy to replace, break it off and buy a new one.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-19-2017, 04:47 PM   #4
Exrald
Exrald's Avatar
What do you mean by wheel leverage? and would that hurt the wheel?
Old 09-19-2017, 04:48 PM   #5
Exrald
Exrald's Avatar
Yeah. I'm getting a new hub with it too. The problem is removing the broken stud...
We drilled it already,but it takes a long time. and I don't have the proper tools
Old 09-19-2017, 08:12 PM   #6
humfrz
I think he is talking about removing the other lug nuts, then stick a crow bar behind the wheel and snap off the busted stud.
(or use a cold chisel to cut it off)
Or, you could do it the "humfrz way" ....... tighten the other lug nuts, carefully drive it up to the local auto shop and have them take care of it ......
humfrz
Old 09-19-2017, 09:05 PM   #7
Pull the stud out as far as you can. Put t tee bar on the nut. Stand on outer end of tee bar. Works about 60% of the time and no risk to the wheel.
Old 09-20-2017, 12:14 AM   #8
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Couldn't resist...in seriousness, though, good to know in a pinch.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 09-20-2017, 12:48 AM   #9
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Is the stud really broken or did you apply enough pressure to push it out of it's slot while trying to force the lug nut on? When you said free-spinning, only reason (IMO) it would be free spinning is if the stud had been push out of it's slot in the hub or the splines on the extended stud/hub has been smoothed out from constant force trying to spin it.
If it's the front hub that the stud is free spinning on, you might just be able to jack up the car high enough and squeeze behind the wheel (if the wheel is still on) and remove the brake caliper/whole hub assembly and maybe see if the stud is completely off or just needed to be hammered back in.
Bach415 is offline   Reply With Quote
Old 09-20-2017, 09:39 PM   #10
ls1ac
ls1ac's Avatar
remove the other nuts then pull out on the other side of the tire to put the stud in a bind so that it will not turn then use a cobalt drill on the center of the stud until you are to the depth of the nut. then pull harder on the tire and it will break the much weekend stud.
an alternate is to use a grinder blade on the back of the stud, but it is often difficult to get by the shield on the back. then again pull on the side of the tire to pull the stud through, it may be hard to pull through as the stripped splines may be tapered
alternate three is to use a air chisel to cut the back off, then pull on the tire to pull it through.
Old 09-20-2017, 10:34 PM   #11
Exrald
Exrald's Avatar
It's the rear wheel. Most likely that the spline got smoothen out due to over torque...
Old 09-20-2017, 10:36 PM   #12
Exrald
Exrald's Avatar
I searched up what a Tee-bar is... There's so many kind that idk which one to use. LOL #imanoob
Old 09-20-2017, 11:07 PM   #13
humfrz
Well, it's NOT this kind .......
humfrz
Old 09-20-2017, 11:10 PM   #14
humfrz
Bubba says to take a torch and cut it out ........
You have been dinking around with that thing long enough .......
humfrz
First stud broken Jajanken86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 11-10-2016 08:07 PM
How to prevent broken wheel stud vincelive123 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 01-11-2016 07:21 PM
Broken Exhaust Stud During FP Install EvoPrecision8 Engine, Exhaust, Transmission 28 03-31-2015 03:21 PM
Broken stud on stock header BAMF86 Engine, Exhaust, Transmission 1 06-06-2014 04:27 PM
Broken Stut mount Stud. Anyone Did This Before? Figo Issues | Warranty | Recalls / TSB 3 07-19-2013 10:29 AM
