Drives: NSX, G35, E36 328i racecar
Sparta Evolution Braking Systems
Hello FT86 Club!
We are Sparta Evolution, and we would like to introduce ourselves as a new FT86Club forum sponsor! Sparta Evolution is an engineering, R&D, and manufacturing firm based in Redmond, WA (just outside Seattle). We specialize in big brake kits for racing applications, as well as high performance OE replacement pads and rotors! Founded in 2007, we have been a track focused company since our inception. Our first product, the Sparta Evolution Triton braking system, was launched after 5 years of benchmarking, research, testing, and product development. Since our 2012 debut, we have supplied and supported over a dozen SCCA, BMWSCCA, NASA, and time attack cars. We were even able to support the Strom Motorsports BMW 328i (E90 pictured below) in their 2015 25-hours of Thunderhill E1 class victory. Though our bread and butter has always been BMW, our success in the market has allowed us to expand our selection across a wide array of domestic and import vehicles commonly found at the track, including the Toyota 86 / Subaru BRZ / Scion FRS! Though we offer 3 tiers of 2 piece calipers depending on your application and intended use, every caliper we manufacture is machined from cold forged 2014-T4 aluminum, and every adapter and hat is machined from cold forged 6061-T4 aluminum. Just as well, each of our rotors are cast and machined with our signature S-groove pattern in the USA, using the highest quality iron recipes available. For the front axle of the ZN6 / ZC6 chassis, we offer both a 4 piston caliper on a 330mm 2-piece rotor, or a 6 piston caliper on a 355mm front 2-piece rotor. With such a light and well balance vehicle, we have found a front BBK is enough for most 86 drivers, but if you’re planning on running high downforce and/or slick tires out on the track, we recommend pairing our 6 piston 355mm front kit with a 4 piston 355mm rear kit. If you’re not looking to upgrade to a BBK just yet, we also offer two different compounds from our Sparta Performance Pad (SPP) lineup. SPP 2.0 is our high performance street compound designed for spirited driving, autocross, and light duty track work, and SPP 3.0 is our street / track hybrid compound, designed for more demanding HPDE track days. Please feel free to reply here or PM us with any questions or comments, and we look forward to contributing to this forum! Trevor W. Sparta Evolution BBK Specifications: Front: 4 piston 2-piece Saturn caliper - 330 x 30 x 52 2-piece rotor 6 piston 2-piece Saturn caliper - 355 x 32 x 52 2-piece rotor Rear: 4 piston 2-piece Saturn caliper - 355 x 32 x 52 2-piece rotor SPP 2.0 Key Features: FMSI D1539 Front • High Initial Bite • Wide Working Temperature Range (up to 400°C) • Stable Cold/Street Performance • Tailored towards Trackday/Autocross Drivers • Stable and Predictable Torque Curve • High Levels of Control and Modulation • Moderate Dust • μ=~0.38-0.43 SPP 3.0 Key Features: FMSI D1539 Front, FMSI D1124 Rear • Low Pad Wear • High Bite and Feel • Extra Wide Operating Range (100°C to 500°C+) • μ=~0.37-0.44 2015 25-hours of Thunderhill E1 Class Champion Strom Motorsports BMW E90 328i |
| The Following User Says Thank You to SpartaEvolution For This Useful Post: | Shark_Bait88 (09-19-2017) |
Drives: 2014 GT86
These kits are track focused, or some of them have dustboots and alikes, for use in eg. winter with roadsalt environment daily driving too?
What is rotor and pads thickness in these kits? How common are pad shapes in these? Is brake bias close to stock? Do kits include steel braided lines? Also advising to post brake fitment templates in this thread for your BBKs. |
| The Following User Says Thank You to churchx For This Useful Post: | SpartaEvolution (09-20-2017) |
#3 | |||
We engineer our kits to be within 1-2% of the stock bias when used with the OE master cylinder. Typically, OE systems are designed with a heavier front bias to promote understeer for safety. In this case, our kit shifts the bias ~1% toward the rear. Yes, all our kits include braided stainless teflon coated brake lines. Quote:
Front 4p 330mm template 86 Front 4P 330mm Fitment Template.pdf Front 6p 355mm template 86 Front 6p 355mm Firtment Template.PDF Rear 4p 355mm template 86 Rear 4p 355mm Fitment Template.PDF |
| The Following User Says Thank You to SpartaEvolution For This Useful Post: | Jonsey (09-19-2017) |
Drives: Too heavy
What’s the price on the 6/4pots app 2.0?
| Greddy Evolution GT IV | kygabe | Engine, Exhaust, Bolt-Ons | 6 | 10-02-2018 05:17 PM |
| GReddy Evolution GT | ShadowReaper | Engine, Exhaust, Transmission | 37 | 03-01-2016 11:00 PM |
| Evolution of 86 build. | African | AFRICA | 153 | 09-17-2014 05:43 AM |
| ROH Evolution R 18x8 +40 | Sinclap2 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 06-23-2014 01:20 PM |
| Evo x the last evolution | 4agze | Other Vehicles & General Automotive Discussions | 15 | 03-05-2011 06:15 PM |
