Old 09-18-2017, 09:01 PM   #1
Turdinator
Señor Member
Turdinator's Avatar
What to ask when choosing a coilover?
I am looking to get some coilovers in the next month or so. I have emailed a few local companies talking about my goals and they are coming back to me with similar responses, they all are offering digressive high flow valving with similar spring rates. What further things should I be asking to help narrow down which way I should jump?
1974 TA22 Celica
2013 86 GT
Old 09-18-2017, 09:29 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
A copy/paste of what you sent them would really help.
Old 09-18-2017, 10:14 PM   #3
strat61caster
strat61caster's Avatar
Consistency and range of damper adjustments (if any, and with proof because they'll all say theirs are great)
Do they recommend a sway bar package and why (if you care about handling)
ineedyourdiddly
Old 09-18-2017, 10:21 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
I can cut and paste when I get home later but basically I said that:
I daily my car and do a 3hr drive about once a month and a 10hr every year so would like something I can back off a bit for those trips but that I also just got my CAMS license (Australian motorsport license) and will be starting to do some hill climbs and motorkhanas later in the year. So something with a good range of adjustment. I am looking for a max of 25mm drop for aesthetic reasons.
Then I had some specific questions for them about their products. For instance I was asking MCA about which set of spring rates the recommended and what I would gain going from Purple X-C to Reds and I asked Ohlins about running stiffer springs would require a re-valve etc.
1974 TA22 Celica
2013 86 GT
Old 09-18-2017, 10:37 PM   #5
Racecomp Engineering
The most important question they should ask you is what type of tire will you be using.
- Andrew
Racecomp Engineering is online now   Reply With Quote
Old 09-18-2017, 10:39 PM   #6
strat61caster
Compete with the car stock first, plunging into an adjustable suspension with funky spring rates could make the car do things it shouldn't. I wish I had spent more time competing with the car stock to bring my driving up to snuff before plunging into suspension.
There's lots of theories on spring rates and it will be a long time until a consensus is reached for this chassis
Oh and stiffer damping does not mean the car will be faster or easier to drive, it usually makes the car harder to drive... Don't be surprised if one day you drive to an event and drive home without touching the adjusters.
ineedyourdiddly
Old 09-18-2017, 10:42 PM   #7
Turdinator
Señor Member
Turdinator's Avatar
- Andrew
If the Aussie dollar wasn't so weak and shipping a killer I'd be calling you guys up
1974 TA22 Celica
2013 86 GT
Old 09-18-2017, 11:10 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
I know what you are saying. If I am honest I want coilovers, I don't need them. I want them because I'd like to go a bit lower, I want to change some aspects of how the car feels, I want to experience what a car with reasonable quality monotube dampers is like to own and learn how adjusting the suspension changes the car.
1974 TA22 Celica
2013 86 GT
Old 09-18-2017, 11:46 PM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
That is beautiful.
That outlook is the entire philosophy behind the mods I have made to my car.
Old 09-19-2017, 01:25 AM   #10
strat61caster
You've got some great perspective. My only word of warning is that even the most reputable companies in the business may not give you what you want, people have spent thousands of dollars on name brand coilovers and been disappointed. Keep your oe suspension handy as it is quite good, and best of luck!
ineedyourdiddly
Old 09-19-2017, 09:41 AM   #11
Jonsey
Jonsey's Avatar
You have MCA in your back yard, I would give them a call. As Andrew said, the type/size of tires and intended use are the biggest things they should be focused on (in addition to what has already been done to the car that could affect spring rate, like aero).
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
choosing between 2 frs's (please help) allowe Scion FR-S / Toyota 86 GT86 General Forum 56 09-26-2016 11:13 AM
Help choosing rims psyclone07 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 02-10-2014 11:21 PM
Need help choosing kit DannyFRS Forced Induction 16 11-15-2013 02:49 PM
Need help choosing... ap5512 Other Vehicles & General Automotive Discussions 23 09-18-2012 06:24 PM
