Old 09-15-2017, 09:27 PM   #1
bzdont
Drives: 2014 BRZ Limited SWP
OFT disabled DTCs
I've tried a couple different OFT tunes -- a Stage 1 (for use with the stock header), and then I switched to Stage 2 UEL after I installed the OFH.
Everything seems to run fine, but looking through the OFT .bin files, it appears that both P0240 and P2096 are disabled by default in both of these tunes. I know that disabling 0240 is very common and needed to prevent CEL with the uncatted header. But why is 2096 (Post Catalyst Too Lean) disabled? Is that needed and/or safe?
Thanks in advance.
bzdont is offline   Reply With Quote
Old 09-15-2017, 10:20 PM   #2
steve99
Thanks in advance.
re enable P2096
Old 09-15-2017, 10:38 PM   #3
bzdont
re enable P2096
Ok thanks.
I haven't messed around with editing yet. When I go to save the file with 2096 enabled, should I allow RomRaider to fix the checksum error?
Old 09-15-2017, 10:49 PM   #4
steve99
Ok thanks.
yes just answer yes to fix checksums
if you using oft it doesnt rearly matter as oft will fix checksums anyway when you load rom
Cruise control temporarily disabled? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 15 06-29-2016 08:35 PM
Help! smart key/keyless entry disabled deadsailor86 Electronics | Audio | NAV | Infotainment 0 09-17-2014 02:58 PM
Disabled the driving aids. Here are my impressions. diss7 Scion FR-S / Toyota 86 GT86 General Forum 284 01-10-2014 07:36 PM
Dealer disabled DRLs = no high beams? Moshpit37 Issues | Warranty | Recalls / TSB 9 03-17-2013 02:15 AM
NAV Voice Directions disabled? ShoGun Electronics | Audio | NAV | Infotainment 0 07-15-2012 09:06 AM
