Old 06-30-2012, 02:34 PM   #1
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Cruise control temporarily disabled?
I hit 1500 miles yesterday and at that same time my cruise control activation light lit up yellow and I was unable to use my cruise control. I turned the car off and then back on and everything was fine again. Anyone else experience this?
Old 06-30-2012, 03:21 PM   #2
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Ok... What did you hit on the car while driving at 48mph, low on gas, and taking a picture of your instrument panel? Maybe your car decided cruise control was not what you needed at that moment.
ashtray is offline   Reply With Quote
The Following 2 Users Say Thank You to ashtray For This Useful Post:
lordtakuban (06-30-2012), Shagaliscious (01-21-2013)
Old 06-30-2012, 03:23 PM   #3
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
Only when my check engine light came on. Turning the car off did not help that cause. ECU glitch?
b.e is offline   Reply With Quote
The Following User Says Thank You to b.e For This Useful Post:
DarrenDriven (07-01-2012)
Old 06-30-2012, 04:08 PM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
Please read his post first .
mashal is offline   Reply With Quote
The Following User Says Thank You to mashal For This Useful Post:
Old 06-30-2012, 09:15 PM   #5
ashtray
Did the light come on before he decided to take out his camera to take a picture of it? Or was he taking a pic of the car hitting 1500 miles, knock something with the knee he was steering with, and disable the cc?
Old 07-01-2012, 04:28 AM   #6
DarrenDriven
NW Region Moderator
ashtray, if you can tell me what I could have possibly "hit with my knee" to cause this to happen then I will consider you intelligent. Until then you just crossed below the intelligence threshold for me to notice you anymore.
If anyone else has had this happen then post up. If not, why not just pretend you don't need to post anything.
The Following User Says Thank You to DarrenDriven For This Useful Post:
CaptainSlow (01-21-2013)
Old 01-21-2013, 07:59 AM   #7
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Darren, I had it happen to me yesterday morning on my way to work. I was baffled, but I'll explain what was going on before mine went "Yellow" and wouldn't turn on/off or function.
It was a little chilly, 41 degrees and dry roads. After a majority of my commute, my fluids were all at operating temperature. Since it was Sunday, there were quite a lot of deserted roadways at 5am. I normally drive with TCS/ESC off, as was the case on this morning. After turning left from a stop sign, I ran through 1st, got a pretty "big" chirp into 2nd, and got a "lil" chirp into 3rd (enough to kick the rear out a smidge). Once I let off of the accelerator and resumed cruising, I noticed the yellow cruise control light and inability to turn it on/off etc.
I'm not sure if running through the gears had anything to do with it, but that is what happened immediately prior to the occurrence of the "yellow cruise control light"
PS... Having been on these forums for a while and seeing the responses of people, I'm fully aware of the "dangers" of driving with ESC/TCS off, but I'm not worried about a 200bhp car being "too much to handle". Yes WOT runs are irresponsible and shouldn't be done on public roads but we're all car guys and give in to the temptation for spirited driving on occasion.
Kwaziekeller is offline   Reply With Quote
Old 01-21-2013, 09:41 AM   #8
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
I've had it happen once also. Similar conditions to above. Traction control off, VSC off. Cruise control on and some spirited driving that involved rear wheels being slide happy. Looked down and noticed the cruise indicator had turned yellow. Pulled over and shut the car off and re-started and it reset.
FRSFirestorm is offline   Reply With Quote
Old 01-21-2013, 10:03 AM   #9
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
^ same thing here. I was driving home from work, which is mostly straight so i had my cruise set, but I had traction and VSC off and got to one of the turns i have to make and slid my car through it. got back up to speed and went to set my cruise only to see it was lit up yellow and not green and wouldnt work... turned the car off and started it back up and it was fine...
Kuzuri is offline   Reply With Quote
Old 01-21-2013, 01:04 PM   #10
NOHOME
Drives: RAVEN
Interesting.
I have to admit that this is the most electronically controlled car I have ever owned, hence I cant really compare it to anything else. Previous car did not even have ABS.
What I have noticed is that I am still not clear on who is driving this car; me or the computer. When I originally got the bug to buy this car, I never dreamed that the wonderful handling was going to be balanced by an endlessly annoying electronic personality. This car really is the beautiful chick that you can't stand!
NOHOME is offline   Reply With Quote
Old 01-21-2013, 11:38 PM   #11
Porsche
Drives: 2013 BRZ Ltd. MT
The following is speculation, just an educated guess.
It may be that when the ECU receives data indicating wheel slip, it shuts the cruise control option OFF.
The ECU doesn’t know whether this slip was driver generated or the result of slippery road surfaces where it is considered inadvisable to activate cruise control.
The highway patrol reports many single-car crashes resulting from drivers employing cruise control in rain, snow, and ice conditions. The general recommendation is to turn cruise control OFF in these conditions.
One does not want the cruise control spinning wheels as the tires hydroplane or cross a patch of snow and ice; this could suddenly snap a car left or right, catching out an inattentive driver and putting him off the road. He, or his lawyer, is likely to blame the car.
I think this ECU programming would be a sensible and clever method of protecting both the less-skilled driver, and the company itself from potential lawsuits arising from crashes. This impresses me as an excellent design feature if it is true.
Porsche is offline   Reply With Quote
The Following 3 Users Say Thank You to Porsche For This Useful Post:
Demandred7 (06-30-2016), Moshpit37 (01-22-2013), wireman957 (06-29-2016)
Old 01-22-2013, 08:52 AM   #12
FRSFirestorm
Red is Fastest
I agree and suspected this was exactly what happened when mine disabled.
I've had a couple sphinkter pucker moments with cruise control and slick roads in other vehichles. Good idea to disable it.
Old 01-22-2013, 09:30 AM   #13
NOHOME
Drives: RAVEN
The issue with all this computer generated control is that it is much like Government services:
Before the Government can give you anything, first hey have to take it away from you".
I feel the same way about the endless electrical interference from the FRS. First annoying car I have ever owned; it seems impossible to drive this car without some retarded light beeping for some stupid reason or other. I also realize that it is here to stay regardless of what I buy.
Old 06-29-2016, 05:44 PM   #14
FRS Justin
Drives: 2013 Asphalt FRS
you could always shut off the dtc's with ECUTEK
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Anyone considering a cruise in dallas Exhaust Southwest 220 09-18-2012 02:12 PM
Seaside Cruise Saturday, July 7th DarrenDriven Northwest 33 07-09-2012 02:19 AM
FR-S as a relaxing cruise... eriktherod Scion FR-S / Toyota 86 GT86 General Forum 3 06-07-2012 08:44 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
Went on lil Sunday cruise w friend... ichitaka05 Other Vehicles & General Automotive Discussions 11 07-07-2011 10:22 PM
