Old 09-12-2017, 07:17 PM   #1
Cycletech
Drives: 2014 Scion FRS Monogram
Fresh reflash low end power loss
Just flashed stage 2 UEL tune. Took car for a ten minute ride and noticed the low end torque and horsepower went very soft and then around 4k RPM it hits and pulls hard to redline. Obviously the cam phasing and ignition timing have alott to do with this. Once the ECU learns this tune should I regain the to mid. My torque dip just got worse basically!?
Cycletech is offline   Reply With Quote
Old 09-12-2017, 07:24 PM   #2
steve99
Accelerator will be "dead" feeling for first few mm of travel. after reflash
Did you ley car idle for at least a minute after reflash, else cams wont operate
Log the tune see if you have high fuel trims, incorrect afr or knock
Old 09-12-2017, 08:06 PM   #3
Cycletech
It was a cold start and had it idle for about 2 minutes.
Old 09-12-2017, 08:59 PM   #4
Tor
Tor's Avatar
Drives: Toyota GT86
Sounds like the AVCS failing to activate indeed.
Sometimes they'll activate, sometimes not. For now you don't have to do anything, they will activate next time you start the car.
Next time you flash and if you have the same problem continue to drive until the engine has heated up. Pull over and let it idle for 10-20 seconds and they will activate.
Tor is offline   Reply With Quote
Old 09-12-2017, 11:56 PM   #5
Cycletech
Tomorrow morning I will be running and testing the car. I will check back in with results. Thanks for the
Tech!
Old 09-13-2017, 08:32 AM   #6
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
It may be my relative newness to OFT and tuning, but is this just dead pedal after reflash? Turn the car on to accessory, depress and release the gas pedal at least 5 times, 5-10 secs for each down/up cycle (you could watch the throttle position on the OFT). Turn car off. If you still have dead pedal, rinse and repeat. It only took me one try to get the pedal feel back after reflash.
Weigaldo is offline   Reply With Quote
Old 09-13-2017, 03:24 PM   #7
Cycletech
It wasn't a pedal response issue. My cams lower RPM stage timing was inoperable. Basically stuck in second stage Upper RPM cam timing so was over scavenging and flat until it got up on the cam.
Its good now anyway, Once I fired it up this morning and warmed for a few minutes it calibrated and all is good. Going to drive this tune for a little bit while ECU learns it and it becomes optimized. I will then fill up on E85 and try out the 85 tune and so can see how it makes a difference apart from the dyno sheets.
Old 09-13-2017, 04:04 PM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
you do have a catless UEL header right?
Old 09-13-2017, 06:02 PM   #9
Cycletech
Of course, CNT catless UEL. Problem is solved if you haven't read the other posts.
Backfire + Loss of power RavioliG Issues | Warranty | Recalls / TSB 2 11-16-2014 09:56 PM
Erractic loss of power at low RPM Bg8780 Issues | Warranty | Recalls / TSB 8 05-01-2013 03:13 PM
Down on power after reflash Stressin Issues | Warranty | Recalls / TSB 22 11-01-2012 04:23 PM
Hi rev power loss? lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 09-29-2012 09:47 PM
CEL, Loss of Traction Light, Loss of Power pituala Issues | Warranty | Recalls / TSB 19 09-05-2012 11:23 AM
