Old 09-11-2017, 12:19 PM   #1
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
What Type of Wood???
Woodworking friends: help!
We bought some MDF boards over the weekend to play around with, and try building things (1/2"). It turns out MDF is all but useless if you want to put screws or even nails in along the edge; even if you pre-drill holes, it is prone to cracking.
What is the ideal type of wood material, that isn't too expensive, that comes in big sheets, or at least large, thin boards, that's straight, and that handles screws and nails for assembly? Plywood seems to be out because it's very floppy, and not at all flat. Input or suggestions welcome. I'm completely new to woodworking, and I've bought a lot of the necessary tools, but I'm not sure what type of wood works best.
For reference, the end goal was to build a pair of racing simulators, but we are starting with building a simple cat house as "practice."
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 09-11-2017, 12:26 PM   #2
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
if you went with a thicker(3/4) plywood you'd be fine and get a B/C grade and it'dd be flat/smooth plus you'll be able to paint it if you want.
Old 09-11-2017, 12:38 PM   #3
Stang70Fastback
A.K.A. Starlord
So, something along these lines?
http://www.homedepot.com/p/23-32-in-...0063/302943420
My issue is I look at a page like this, and there are SO many different types of wood boards that I have NO idea which ones are best to use for these kinds of projects...
http://www.homedepot.com/b/Lumber-Co...vZbqm7Z1z0mcq7
Old 09-11-2017, 01:13 PM   #4
ZoLazoa
Drives: 95 miata mx-5
Purebond from HD is good. If you can spend more baltic birch plywood is good.
Sent from my SM-G935V using Tapatalk
ZoLazoa is offline   Reply With Quote
Old 09-11-2017, 01:31 PM   #5
czechm8
520
czechm8's Avatar
Drives: Series 10 Fr-s #520
As mentioned, the most economical solution is the BCX plywood you referenced, or 12-ply Baltic birch type plywood. I would not go thinner than the 3/4" or 23/32nds. MDF has its advantages and disadvantages - not the best solution in this case.
I do see a potential problem with the design of your cat house though. That long horizontal section near the top is not supported on one end (unless you plan to affix it to a wall). Most cats aren't too heavy, but it wouldn't take much to break off that section with a jumping or landing cat.
I would not canti-lever that section more than half the distance you are currently showing (assuming you use 3/4" ply) or you risk it snapping off under stress.
czechm8 is offline   Reply With Quote
The Following User Says Thank You to czechm8 For This Useful Post:
Tcoat (09-11-2017)
Old 09-11-2017, 01:53 PM   #6
humfrz
I suggest plywood (good one side); thickness depends upon the load put on it and how it's supported.
humfrz
Stang70Fastback (09-11-2017)
Old 09-11-2017, 01:56 PM   #7
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Why you gotta call his cat(s) fat?
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
Stang70Fastback (09-11-2017), Tcoat (09-11-2017)
Old 09-11-2017, 02:46 PM   #8
Stang70Fastback
A.K.A. Starlord
Thanks! I guess we can try some 3/4" plywood, or the birch stuff. This is useful information!
Jerk!
Lol, the image I provided was just to give a frame of reference for what we are building. It isn't a finished model. There will be more cutouts (for example at the top of that second ramp) and there will be a PVC pipe also supporting the end of that cantilevered section
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Tcoat (09-11-2017)
Old 09-11-2017, 04:14 PM   #9
cjd
cjd's Avatar
Drives: 2017 BRZ
At a big box store, the Birch plywood is likely ok, but you want the stuff with a finish grade surface.
Proper Baltic Birch is 3x the cost but can be worth it... You'll need to go to Owl Hardwood or similar. You get this for uniformity and because it's not a thin crappy surface veneer that'll fail first (and all too often, easily).
Your project will be fine in mdf. Use glue, jigs, and clamps. You can also pin while glue dries with a finish nailer or brad nailer. Screw's and nails require predrilling but also work. You do need to be smart about joint construction no matter what or you'll experience material failure.
Holler if you want a bit more of a hand than quick forum blurbs... I'm currently building a sound rig for my sister's band, and will get back to some built-in cabinets I'm building once I wrap that up... Had you not moved into the boonies I'd even be able to say I'm nearby.
C
The Following User Says Thank You to cjd For This Useful Post:
Dadhawk (09-11-2017)
Old 09-11-2017, 04:30 PM   #10
Stang70Fastback
A.K.A. Starlord
C
I wouldn't mind some lessons. I'm far from "properly equipped" to do this kind of stuff, but I did finally buy a nice router, and yesterday I discovered how easy it is to clone pieces of wood using a router bit with a bearing. SO BRILLIANT. I'm thinking I should consider buying some more bits to allow me to make proper joints (either 45-degree joints, or whatever you call the ones where you cut a groove, and slot the other piece into it), but I also need to get some metal guides I can clamp down that will keep those cuts perfectly straight before I get too fancy.
Old 09-11-2017, 04:56 PM   #11
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Far be it from me to pass on what my girlfriend said.....shes a carpenter by day...
and I quote...." the best wood for nailing is morning wood, it can take a hammering for a while, but you must be careful about banging it too long as it my become soft ".......
So there you have it, from and expert no less...........your choice of wood should be morning wood.
IceFyre13th is offline   Reply With Quote
The Following 5 Users Say Thank You to IceFyre13th For This Useful Post:
Clipdat (09-11-2017), Spuds (09-11-2017), Stang70Fastback (09-11-2017), Takumi788 (09-11-2017), wireman957 (09-11-2017)
Old 09-11-2017, 05:23 PM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Can confirm.
Source: .... uh...
Old 09-11-2017, 06:45 PM   #13
cjd
cjd's Avatar
Drives: 2017 BRZ
You can do a ton with a sawboard and circular saw, router, and hand drill...
The downside of MDF is its dust... It's horrible on your lungs and gets everywhere. I've had to rebuild my router because of it, and I mostly avoid it now.
Anyhow, you know where to find me. If I'm not being grumpy about being slow as heck I might be inclined to be helpful...
Old 09-11-2017, 07:03 PM   #14
DO NOT confuse with mourning wood!
Two totally different things.
echo419 (09-12-2017), IceFyre13th (09-12-2017)
Removable Wood Flooring for Trunk Outlawstar98 Interior Parts (Incl. Lighting) 39 06-13-2021 12:11 PM
Trunk sub box molded to fit (plexi or wood) Matey Electronics | Audio | NAV | Infotainment 14 06-11-2015 11:47 AM
Fort Leonard Wood brokedrifter Rocky Mountains / Great Plains 8 02-27-2015 10:53 PM
