| Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
A.K.A. Starlord
Drives: 2015 Series.Blue
What Type of Wood???
Woodworking friends: help!
We bought some MDF boards over the weekend to play around with, and try building things (1/2"). It turns out MDF is all but useless if you want to put screws or even nails in along the edge; even if you pre-drill holes, it is prone to cracking. What is the ideal type of wood material, that isn't too expensive, that comes in big sheets, or at least large, thin boards, that's straight, and that handles screws and nails for assembly? Plywood seems to be out because it's very floppy, and not at all flat. Input or suggestions welcome. I'm completely new to woodworking, and I've bought a lot of the necessary tools, but I'm not sure what type of wood works best. For reference, the end goal was to build a pair of racing simulators, but we are starting with building a simple cat house as "practice."
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#2 |
Drives: 2014 BRZ Limited
if you went with a thicker(3/4) plywood you'd be fine and get a B/C grade and it'dd be flat/smooth plus you'll be able to paint it if you want.
#3 | |
A.K.A. Starlord
http://www.homedepot.com/p/23-32-in-...0063/302943420 My issue is I look at a page like this, and there are SO many different types of wood boards that I have NO idea which ones are best to use for these kinds of projects... http://www.homedepot.com/b/Lumber-Co...vZbqm7Z1z0mcq7
#4 |
Drives: 95 miata mx-5
Purebond from HD is good. If you can spend more baltic birch plywood is good.
Sent from my SM-G935V using Tapatalk |
#5 |
520
Drives: Series 10 Fr-s #520
As mentioned, the most economical solution is the BCX plywood you referenced, or 12-ply Baltic birch type plywood. I would not go thinner than the 3/4" or 23/32nds. MDF has its advantages and disadvantages - not the best solution in this case.
I do see a potential problem with the design of your cat house though. That long horizontal section near the top is not supported on one end (unless you plan to affix it to a wall). Most cats aren't too heavy, but it wouldn't take much to break off that section with a jumping or landing cat. I would not canti-lever that section more than half the distance you are currently showing (assuming you use 3/4" ply) or you risk it snapping off under stress. |
| The Following User Says Thank You to czechm8 For This Useful Post: | Tcoat (09-11-2017) |
#6 |
I suggest plywood (good one side); thickness depends upon the load put on it and how it's supported.
humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Stang70Fastback (09-11-2017) |
#7 | ||
Proud of BOXER
Drives: Subaru Boxer
Why you gotta call his cat(s) fat?
| The Following 2 Users Say Thank You to Clipdat For This Useful Post: | Stang70Fastback (09-11-2017), Tcoat (09-11-2017) |
#8 | ||
A.K.A. Starlord
Lol, the image I provided was just to give a frame of reference for what we are building. It isn't a finished model. There will be more cutouts (for example at the top of that second ramp) and there will be a PVC pipe also supporting the end of that cantilevered section
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | Tcoat (09-11-2017) |
#9 |
Drives: 2017 BRZ
At a big box store, the Birch plywood is likely ok, but you want the stuff with a finish grade surface.
Proper Baltic Birch is 3x the cost but can be worth it... You'll need to go to Owl Hardwood or similar. You get this for uniformity and because it's not a thin crappy surface veneer that'll fail first (and all too often, easily). Your project will be fine in mdf. Use glue, jigs, and clamps. You can also pin while glue dries with a finish nailer or brad nailer. Screw's and nails require predrilling but also work. You do need to be smart about joint construction no matter what or you'll experience material failure. Holler if you want a bit more of a hand than quick forum blurbs... I'm currently building a sound rig for my sister's band, and will get back to some built-in cabinets I'm building once I wrap that up... Had you not moved into the boonies I'd even be able to say I'm nearby. C |
| The Following User Says Thank You to cjd For This Useful Post: | Dadhawk (09-11-2017) |
#10 | |
A.K.A. Starlord
#11 |
Drives: Mazdarati
Far be it from me to pass on what my girlfriend said.....shes a carpenter by day...
and I quote...." the best wood for nailing is morning wood, it can take a hammering for a while, but you must be careful about banging it too long as it my become soft "....... So there you have it, from and expert no less...........your choice of wood should be morning wood.
| The Following 5 Users Say Thank You to IceFyre13th For This Useful Post: | Clipdat (09-11-2017), Spuds (09-11-2017), Stang70Fastback (09-11-2017), Takumi788 (09-11-2017), wireman957 (09-11-2017) |
#12 | |
Drives: 2005 Toyota Camry
Source: .... uh... |
#13 | |
Drives: 2017 BRZ
The downside of MDF is its dust... It's horrible on your lungs and gets everywhere. I've had to rebuild my router because of it, and I mostly avoid it now. Anyhow, you know where to find me. If I'm not being grumpy about being slow as heck I might be inclined to be helpful... |
#14 | |
Two totally different things.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | echo419 (09-12-2017), IceFyre13th (09-12-2017) |
| Removable Wood Flooring for Trunk | Outlawstar98 | Interior Parts (Incl. Lighting) | 39 | 06-13-2021 12:11 PM |
| Trunk sub box molded to fit (plexi or wood) | Matey | Electronics | Audio | NAV | Infotainment | 14 | 06-11-2015 11:47 AM |
| Fort Leonard Wood | brokedrifter | Rocky Mountains / Great Plains | 8 | 02-27-2015 10:53 PM |
