Drives: FRS
Can I go any lower? Rear suspension geometry
![]() This is what my rear control arm looks like. Am I already compromising geometry. Would like to get another 1/4 inch or so if possible. All stock in back with coilovers. |
Drives: 2013 Asphalt Frs
You would be fine at the height your looking for, just recommend adjustable lower control arms or camber bolts in the long term if you want OEM geometry and camber adjustment, other than that your good to go
| The Following User Says Thank You to GoZ21 For This Useful Post: | Whooosah (09-06-2017) |
Drives: '24 GR86
Get LCAs from Stance or PBM where they lower the coiler mounting point by 1-2". That will allow you to raise the height of the coilover, but keep your current ride height.
After that, your options are to either raise the subframe, or add rear drop knuckles.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | Whooosah (09-06-2017) |
#4 | |
To the OP, I wouldn't go any lower if handling is a priority. - Andrew |
| The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post: | strat61caster (09-05-2017), TylerLieberman (09-05-2017), Whooosah (09-06-2017), wparsons (09-05-2017) |
| Rear Suspension Sitting Lower Than Front. | Zeuseidon | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 12-06-2016 06:20 PM |
| FS: Stock suspension and rear lower control arms | nickg | Brakes, Suspension, Chassis | 1 | 08-20-2016 08:41 PM |
| Suspension Geometry | einrejosh | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 02-13-2015 07:16 PM |
| Ideal ride height for best suspension geometry? | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 8 | 11-19-2013 07:46 AM |
| Questions on Suspension Geometry | Zach3794 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 07-02-2013 10:53 PM |
