Old 08-30-2017, 04:38 PM   #1
Whooosah
Drives: FRS
Can I go any lower? Rear suspension geometry
This is what my rear control arm looks like. Am I already compromising geometry. Would like to get another 1/4 inch or so if possible. All stock in back with coilovers.
Whooosah is offline   Reply With Quote
Old 09-05-2017, 11:17 AM   #2
GoZ21
GoZ21's Avatar
Drives: 2013 Asphalt Frs
You would be fine at the height your looking for, just recommend adjustable lower control arms or camber bolts in the long term if you want OEM geometry and camber adjustment, other than that your good to go
GoZ21 is offline   Reply With Quote
The Following User Says Thank You to GoZ21 For This Useful Post:
Whooosah (09-06-2017)
Old 09-05-2017, 12:01 PM   #3
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Get LCAs from Stance or PBM where they lower the coiler mounting point by 1-2". That will allow you to raise the height of the coilover, but keep your current ride height.
After that, your options are to either raise the subframe, or add rear drop knuckles.
The Following User Says Thank You to TylerLieberman For This Useful Post:
Old 09-05-2017, 12:44 PM   #4
Racecomp Engineering
This will give you bump travel, but does not improve suspension geometry.
To the OP, I wouldn't go any lower if handling is a priority.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
strat61caster (09-05-2017), TylerLieberman (09-05-2017), Whooosah (09-06-2017), wparsons (09-05-2017)
Rear Suspension Sitting Lower Than Front. Zeuseidon Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 12-06-2016 06:20 PM
FS: Stock suspension and rear lower control arms nickg Brakes, Suspension, Chassis 1 08-20-2016 08:41 PM
Suspension Geometry einrejosh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 02-13-2015 07:16 PM
Ideal ride height for best suspension geometry? Hachi86Roku Tracking / Autocross / HPDE / Drifting 8 11-19-2013 07:46 AM
Questions on Suspension Geometry Zach3794 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-02-2013 10:53 PM
