Old 02-12-2015, 02:04 PM   #1
einrejosh
einrejosh's Avatar
Drives: 2014 Scion FR-S
Suspension Geometry
Hi guys, I just got an alignment from Speed Element on monday 2/9. I installed Fortune Auto 500s and Stance lower control arms since in most pictures the rears seem to not go so low. I installed them myself since I am not baller enough to pay people for labor. I did everything right of course, preload and ride height all using a caliper. Only problem was camber in the front and rear, and rear toe. So I fix my alignment enough in my garage to have it drive-able to Speed Element, and they tell me if I want to go -2 degrees in the front I need camber bolts, so I went ahead and bought it and now here's my question.
-Does my suspension geometry get messed up if I have two camber adjustments on each side? (eccentric bolt and top hat) and none of them match?
-Why this concerns me is because the both top hats are at different measurements, and both bolts are at different measurements. I would rather have the top hats maxed out as a reference point and adjust the eccentric bolts since maxing out the top hats barely gave me any negative camber and then just adjust the eccentric bolts.
On another note, I will no longer be going to Speed Element for service. I feel they half assed my alignment, they half assed the install of the eccentric bolt, they didn't torque anything down from what I saw. I couldn't observe the Tech working on my car, even though I'm a Tech myself, they did the alignment where its "good" on paper but less likely when you drive it, their Techs took multiple smoke breaks, and only one of them is ASE certified, which sometimes matters if you care about your car and who works on it. All in all, I feel Speed Element is a Performance Show Car shop only for show, the only reason I would only go here in the future is because of one of the sales rep, Jason, he would have to be the coolest there. I'll probably just go here for parts now in the future.
On another note, this place has a shit ton of awards for their Evos, so I say check em out for that, but that's all.
I'll upload some pics later of my car, but yeah, if anyone can answer my question that would help, I'll just get an alignment else where.
-Final alignment specs, -2 degrees in the front, 0 toe, -1.5 in the rears (need after market toe arms to go less camber) and .09 toe.
einrejosh is offline   Reply With Quote
Old 02-12-2015, 02:53 PM   #2
wparsons
wparsons's Avatar
Are you sure the upper mounts were installed correctly? I have -2* up front without adjustable upper mounts, just whiteline bolts and slightly slotted upper holes.
From a geometric standpoint, you're better off maxing out the camber at the knuckle then adjusting further at the upper mount. The less you increase the angle of the strut the better.
flickr
Old 02-12-2015, 03:09 PM   #3
Racecomp Engineering
This. Max out the bolts for a better SAI.
It would be unacceptable to me to have the camber plates and bolts set differently side-to-side. That gets you different SAI on each side, and an off center roll center (I think). The difference may be minor, but that's not the way to do an alignment.
- Andy
Old 02-12-2015, 04:25 PM   #4
einrejosh
einrejosh's Avatar
Yeah I installed it correctly it's just my car had been in an accident causing the left caster to be 5.8 I think compare to the right. That may have been the reason why my camber was still close to 0 when maxed out. Same problem when I had stock suspension, my right side had more camber than the left
Old 02-12-2015, 04:26 PM   #5
einrejosh
einrejosh's Avatar
- Andy
So max bolts out and adjust top hats after for better SAI is what you're saying?
Old 02-12-2015, 05:25 PM   #6
Yup.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
wparsons (02-13-2015)
Old 02-12-2015, 08:23 PM   #7
OmarYasin
OmarYasin's Avatar
I go to motorsport techniques. They are very familiar with our platform. As far as i know u should max the cam bolt and do final adjustments via camber plate-omar
OmarYasin is offline   Reply With Quote
Old 02-12-2015, 08:27 PM   #8
OmarYasin
OmarYasin's Avatar
There should always be more caster on one side i believe driver side
Old 02-12-2015, 09:33 PM   #9
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
If you think they half-asses it, they might have. What was your SAI after alignment?
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
Old 02-12-2015, 10:53 PM   #10
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
- Andy
uhh… what is SAI ?
Old 02-12-2015, 11:24 PM   #11
Originally Posted by Black Tire View Post
uhh… what is SAI ?
Steering axis inclination.
- Andy
Black Tire (02-12-2015)
Old 02-12-2015, 11:46 PM   #12
einrejosh
einrejosh's Avatar
I'll have to look for the paper work from before. I went to toyota for my last alignment(oem still) and big O before that (still oem) and both gave me the second paper with SAI but Speedelement didn't give me the second paper with the SAI so I'll just assume they didn't give it or want to give it to me because of half ass labor.
Old 02-13-2015, 12:01 AM   #13
ayau
Drives: Some rust bucket
uhh… what is SAI ?
[ame]http://www.youtube.com/watch?v=IUcZ63unEyU[/ame]
The Following 2 Users Say Thank You to ayau For This Useful Post:
Black Tire (02-13-2015), killboy (02-13-2015)
Old 02-13-2015, 07:50 PM   #14
wparsons
wparsons's Avatar
Caster doesn't affect camber with the wheels straight ahead... if you have unequal camber side to side, try re-centering the subframe.
Are the camber plates on the right side of the car? Usually if you're not getting significant negative camber from the plates it's because they're on the wrong side.
flickr
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 06:06 PM
Ideal ride height for best suspension geometry? Hachi86Roku Tracking / Autocross / HPDE / Drifting 8 11-19-2013 08:46 AM
Questions on Suspension Geometry Zach3794 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-02-2013 11:53 PM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
Lowering & Geometry Issues DBee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 05-10-2013 06:17 PM
