Old 08-27-2017, 11:58 PM   #1
QTR FMS
Drives: brz
least grippy tires for drifting?
hi guys,
im drifting in a small go kart track so it really low speed track and its hard to keep the wheel spinning as much as i want im more sliding than drifting doing my best to carry the most speed i can get so im not using lots of angle.
the stock tire is really grippy to drift and expensive with.
i tried NANKANG ns-20 205/40r17 its alot better but still not as slippery as i want it smokes and spin but it still grips up unless i keep pulling ebrake and clutch kick.
i tried ACHILLES ATR-K ECONOMIST195/40r17 it doesn't last as long i think its chucks way before running out of threads and it makes the gear ratio way to short.
by the way im using e85 and uel headers.
thanks.
QTR FMS is offline   Reply With Quote
Old 08-28-2017, 12:09 AM   #2
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
You are welcome
Kronos is offline   Reply With Quote
The Following User Says Thank You to Kronos For This Useful Post:
QTR FMS (08-28-2017)
Old 08-28-2017, 12:42 AM   #3
QTR FMS
Drives: brz
Originally Posted by Kronos View Post
You are welcome
i actually was thinking of trying it lmao it would be fun , but no seriously i want something i could find in onlinetires.com.
thanks
Old 08-28-2017, 01:07 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Maybe try also lowering wheel size to R16, as there are even narrower tires available for those, and play a bit with alignment, if that's what you adjust car for, especially if on NA power.
Imho it shouldn't matter much which specific tire model/brand. Rather lot of seat time .. which would mean lot of tires burned .. due what "best" choice would be cheapest tires of whatever type. Local pro drifters for training often using multiple sets of used tires from some tire shop, just changing out when yet again another one pops after few laps around.
The Following User Says Thank You to churchx For This Useful Post:
Old 08-28-2017, 01:20 AM   #5
fatoni
Steer clear of Adam's
Drive upgrades. Don't buy them.
The Following User Says Thank You to fatoni For This Useful Post:
QTR FMS (08-29-2017)
Old 08-28-2017, 01:30 AM   #6
QTR FMS
Drives: brz
lol i dont know how to check grange schedule most of the times the events are private or canceled.
and willow spring feels boring on low hp car.
is there any other tracks that i dont know about? i know they did event at San Diego last month.
Old 08-28-2017, 01:35 AM   #7
QTR FMS
Drives: brz
the best part of drifting frs that the tire last three drift events at adam's or more than an hour drifting straight.
the tires cost from 45-60 so its not a big deal to get new tires.
but yeah going a size smaller is not a bad idea im gonna try it.
thanks
Old 08-28-2017, 03:55 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
I've seen cases of tire popped in less then 10 minutes. I have seen case of wheel studs broken in 2nd minute. If drifting is your thing, it's always worth to carry set or two of extra wheels with premounted tires and good jack to speedup remounting. Tires are wearable, of very short life at that for this specific usage type. It's not so much if tire will wear down or blow up, but when. Also worth using cheap wheels that you don't care much. Imho you don't want to drive half a track with blown tire to place where you'll put new wheel/rubber with some uber expensive bling forged wheels.
Unless you are really into drifting that much, imho it's simpler/much cheaper to get into HPDE with occasional drift out of some curvers for fun. With that your tires should last few track days (depending on frequency of which it may mean even half a season or season for you), not minutes/hour. Another way to save on tires for drifting is not to adjust car, but to adjust environment , ice/snow track drifts also let save on wearables a lot.
P.S.
Except from more fitting for drift alignment you may think also of 2nd brake caliper bracket (and caliper itself) for rear brakes and hydraulic handbrake. I don't think stock standing brake will last long if drift-abused.
The Following 2 Users Say Thank You to churchx For This Useful Post:
JazzleSAURUS (08-28-2017), QTR FMS (08-29-2017)
Old 08-28-2017, 04:12 AM   #9
QTR FMS
Drives: brz
i always carry atleast 2 tires and floor jack , sometime even 6 tires it is funny watchinng people reaction when they see the tires in the backseats.
im using xxr wheels and stock wheel and funny thing my xxr wheel lasted more than tj hunt wheel did i was there the same day he broke his wheel and i did similar thing a couple of times and ddint break 100$ wheel (xxr).
im good at drifting i can link every corner except the straight line i avoid monjing and i always get complements and people ask me for a ride along so im past the point of using used tires and the stock tire and ns-20 last really long i dont even worry about the tire life and i actually want to make it shorter by having more wheel spin without going f/i
Old 08-28-2017, 04:16 AM   #10
QTR FMS
Drives: brz
im not gonna install a hydro cause this is my daily im waiting for my project car to be done.
and i want to progress before jumping to a car twice the power so even a little more wheel spin will help cause right now i drift with full throttle no lift until transitioning so i want to get used to throttle modulation more than on off switch.
Old 08-28-2017, 07:45 AM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
QTR_FMS: imho that's the beauty of dual calipers - you don't have to touch/connect to stock brakes/their lines to add hydro brake, even stock parking brake can be left as is, so by that imho nothing will be changed daily driving reliability/capability wise. Just mount another set of stock calipers on rear wheels with something like this.
Old 08-28-2017, 08:19 AM   #12
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
Just find the hardest compound tires you can
Slammillionaire is offline   Reply With Quote
Old 08-28-2017, 08:42 AM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by QTR FMS View Post
im good at drifting
If you're actually at the level where you can claim you are good at drifting, you'll soon realize that you need to have decent grip front/rear to enhance your car control capabilities, which defeats the point of this thread.
So how good are you?
The Following User Says Thank You to mav1178 For This Useful Post:
e1_griego (08-28-2017)
Old 08-28-2017, 09:32 AM   #14
LudwigMiles
Drives: '13 BRZ
Drifting is a great way to drive slow.
LudwigMiles is offline   Reply With Quote
The Following 2 Users Say Thank You to LudwigMiles For This Useful Post:
Somerandom18 (08-28-2017), Teseo (08-28-2017)
Large tires with spacers in back affect of drifting Jake_86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-17-2015 11:15 AM
Regret grippy tires? stock Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 04-11-2014 04:34 PM
Best tires for drifting? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 10-10-2012 12:55 PM
More grippy tyre only front. Mars2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-08-2012 07:02 AM
grippy tires, faster laps... fistpoint Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-30-2012 03:57 AM
