Super Saiyan
Drives: 9000 HP FRS
Coilover VS Spring/Shock
what would be better? ive been looking at either Tein Flex A of Flex Z or go with lowering springs and shock combo. the car is my daily all year round(during winter) and i like the idea of being able to adjust the height for summer and winter ride. from other peoples thoughts and knowledge what would you reccomend?
Coil overs are springs and shocks.
Although the ability to adjust heights for summer and winter sounds great the question is would you actually do it? If yes then it may be worth while. Keep in mind that you may need to get an alignment each time you changed heights though. I have the RSR Super low springs and winter drive my car with no issues.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#3 | |
Super Saiyan
Drives: 9000 HP FRS
Here's what some aftermarket adjustable coilovers look like after living through some winters. In a few years you may not be able to adjust ride heights. Springs and struts can give you just as much if not more of what you want while being a little lower maintenance and longer lifetime.
Also take a look at this thread: http://www.ft86club.com/forums/showthread.php?t=121262 ![]() ![]()
#5 | |
Super Saiyan
Drives: 9000 HP FRS
yeah i dont want that lol even though the Tein Flex A says its all coated and protects from rust and protects against chipping and peeling it still brings concern. i suppose i could get bigger wheels for summer as this is the look im going for
Time Traveller
Very shortly, I'm going to be swapping out my RS*R Sports-i coilovers for Showa Evolution spring/shock combo. Reason being is that I want a less complicated setup that still lowers the car a little and offers great ride. The Sports-i's have been fantastic but they include features I currently don't need. Extra features = more potential points of failure. As the original OEM shock manufacturer Showa knows this cars suspension perhaps better than any other aftermarket company. So I told myself why not give it a shot? This is a gen 2 design that should be even more durable than OEM components. Let's see.
#7 | |
Drives: 15 BRZ LTD, 05 FXT
I run ST's, the less expensive little brother to the KW V1's, and they wear well also. Every wheel and tire change I use a some WD40 and a nylon brush to clean the threads, then put a light coating of silicone grease on the threads. I used to use a copper based antisieze, like Wurth DBQ, or the Permatex copper, but have moved to silicone lubricant since it stands up really well, and is easier to remove. A tube of it will last the life of your coilovers and then some applying it twice a year if you're not overly generous.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | Racecomp Engineering (08-24-2017) |
Drives: 2005 Toyota Camry
just remember that adjustable coilovers of any kind, no matter how durable, require you to inspect them periodically.
Maybe not every week, but at least once every 1-3 months. Coatings are great but spring collars still move around and come loose. Same with upper mounts. If you are the "install and forget it" type, get spring/shock. |
| The Following 4 Users Say Thank You to mav1178 For This Useful Post: |
#9 | |
Super Saiyan
Drives: 9000 HP FRS
#10 |
Drives: 2019 Mazda Miata RF
Technically, the stock spring and damper setup, IS a coilover
| The Following User Says Thank You to Gunman For This Useful Post: | strat61caster (08-23-2017) |
#11 | |
A proper spring/shock combo should last you as long as the OEM setup, somewhere at least 4-6 years if not longer. Zero maintenance other than checking for play in bushings, washing away excessive buildup of road grime/dust, and not attempting to drive in any condition where you will bottom out the suspension. |
#12 |
Super Saiyan
Drives: 9000 HP FRS
[QUOTE=mav1178;2967364]A proper spring/shock setup should not only last you a long time, it would probably never need to be serviced as long as you install it properly with the required bumpstops, new dust boots, and possibly new upper mounts at the same time.
A proper spring/shock combo should last you as long as the OEM setup, somewhere at least 4-6 years if not longer. Zero maintenance other than checking for play in bushings, washing away excessive buildup of road grime/dust, and not attempting to drive in any condition where you will bottom out the suspension.[/QUO so much knowledge in you lol thanks . but as long as i dont go offroading i should be fine i think aha the roads here arent THAT bad
#13 |
Here's something I wrote up a little while ago on this topic:
http://www.ft86club.com/forums/showthread.php?t=45542 |
| Showa spring/shock available soon | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 110 | 01-04-2023 03:03 PM |
| BR Racing Coilover shock keeps blowing | Moooiiissst | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 11-21-2016 05:16 PM |
| Suspension UPGRADE - Shock/Spring Pkg vs. Coilover System - Which to choose? | themajesticone | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 80 | 11-14-2014 06:01 AM |
| coilover shock body height adj | garfull | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 05-19-2013 03:32 AM |
