Old 08-19-2017, 07:36 PM   #1
Respect BRZ
Old Mechanic
Drives: 2013 Limited BRZ
Random beeping.
So last month I replaced my battery to a Mazda Miata battery. No I don't recommend it. But it is smaller and powerful at 25lbs its lighter but not as light as I'd like.
That's when I started to notice a new sound. I get a quick beep in the interior only when in motion. Sometimes a single beep sometimes 3 or 4 beeps quickly in a row. Sometimes a few seconds between sometimes a few minutes or longer between beeping. Also it sounds like it's coming from a multitude of locations. Front left or right or from behind me. (Yes I have the back seat laid down)
Nope nothing in or near my passenger seat. No other lights or indications. When someone does sit in the passenger seat srs airbag system appears to work normally. All other things that make the beeper sound are working normally.
So before I take the passenger seat out and disable the seat sensor just to rule that out. Has anyone else had this or heard of this issue.
2013 BRZ Limited 67k miles. No I'm not taking it to the dealer.
Respect BRZ is offline   Reply With Quote
Old 08-19-2017, 08:24 PM   #2
swarb
So why don't you recommend the miata battery? Blaming a battery for your problems? Poor battery only has one job and you don't like it.
Old 08-19-2017, 08:41 PM   #3
Respect BRZ
Old Mechanic
Just too heavy for its size is all. If you really want a small light battery go for the nicad options. Other than that it's perfect. Great cranking power and it fits with our stock bolts to hold it in place.
I wasn't blaming the battery for this issue just mentioning due to it was disconnected for about an hour. Now I have this issue.
Old 08-19-2017, 11:07 PM   #4
ryoma
ryoma's Avatar
this might sound obvious but have you had any work done to your headunit? maybe some wire in the back is touching a metal backing plate and causing some beep to go through the speakers. or maybe do you have something connected to the headunit (cd, bluetooth, aux)? I don't see how beeping could be coming from different parts of the car if it isn't coming from the speakers.
Old 08-19-2017, 11:07 PM   #5
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
Wouldn't buckling the passenger seatbelt be easier than disabling the sensor? (That should make that particular beeping stop anyway)
Twinz is offline   Reply With Quote
Old 08-19-2017, 11:16 PM   #6
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
No flashing key light on the dash? Could be your key battery running low.
PandaSPUR is offline   Reply With Quote
Old 08-20-2017, 12:46 AM   #7
Respect BRZ
Old Mechanic
Tried that. No help.
Old 08-20-2017, 12:48 AM   #8
Respect BRZ
Old Mechanic
Nope not that either. Tried both keys, and I've had that last year. The light on the key flashes too when the batt is low. No lights on the dash in the cluster nor the airbag or seatbelt for passenger flicker or come on when beeping happens.
Old 08-20-2017, 12:50 AM   #9
Respect BRZ
Old Mechanic
Head unit hasn't been out in well over a year. Last time it was out was for the rear camera add I did wow a long time ago.
Old 08-20-2017, 12:53 AM   #10
Respect BRZ
Old Mechanic
The sound coming from different parts of the car could just be my age and aviation hearing playing tricks on me. And remember this only happens when the car is in motion. And seems to be more frequent under higher G's. or bumps even small bumps. But not always.
I hate intermittent problems.
Old 08-25-2017, 12:42 AM   #11
Respect BRZ
Old Mechanic
Finally found my stereo system cap had come loose from its mounts. So besides the giant ground wire. It wants the case of the unit to be solidly grounded too. Lol
10 Series Beeping Abraxus Scion FR-S / Toyota 86 GT86 General Forum 6 08-05-2020 07:13 PM
beeping when coming to a stop Skin Issues | Warranty | Recalls / TSB 8 07-24-2017 10:06 AM
Battery beeping? Hentai Issues | Warranty | Recalls / TSB 7 02-24-2017 09:50 AM
Beeping noise when shifting Lmiller40 Engine, Exhaust, Transmission 25 05-25-2014 02:41 PM
car beeping after engine shuts off mystic Southern California 10 04-14-2014 05:47 PM
