Old 08-10-2017, 11:02 PM   #1
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Is a oft custom e tune worth it?
Hey everyone, with all my mods added and stage 2 el e85 tune, I make 205whp. My question is, if I get a custom tune from shiv/oft how much additional hp can I get?
Dr. BRZ is offline   Reply With Quote
Old 08-11-2017, 02:26 AM   #2
steve99
If your car stock was around 170hp on that dyno, then probably very little more to be gained , E85 and bolt on is about 40hp over stock with good components
No one does much better than that
Tcoat (08-11-2017)
Old 08-11-2017, 11:09 AM   #3
pancake
Drives: 2015 BRZ Limited MT
What mods do you have to get 205whp? Just aftermarket EL header with e85?
pancake is offline   Reply With Quote
Old 08-11-2017, 06:36 PM   #4
Dr. BRZ
Dr. BRZ's Avatar
tomei el headers, full tomei exhaust, throttle body spacer, silicone inlet tube, k&n air filter, pulleys, greddy snorkel. i have other mods but are lightweight accessories and dont add hp.
Old 08-11-2017, 07:04 PM   #5
Teseo
Drives: frs
Those are good numbers
Old 08-12-2017, 06:59 PM   #6
Dr. BRZ
Dr. BRZ's Avatar
I would hoping to make at least 15extra hp with the custom tune but never mind, not worth it.
Old 08-12-2017, 07:16 PM   #7
Teseo
Drives: frs
With e85 is possible
Old 08-12-2017, 10:18 PM   #8
Dr. BRZ
Dr. BRZ's Avatar
im already on e85 and according to steve99, its not very likely.
Old 08-21-2018, 01:37 PM   #9
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Hey all, sorry to necro this thread.
Considering e-tuning in the near future. Some questions.
- Wouldn't you still need to do a before/after pull on a dyno? Otherwise, you wouldn't really know how much you gained in WHP ?
- Would it be more cost efficient to find a tuner who uses OFT and can do the dyno pulls for you?
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 08-21-2018, 05:39 PM   #10
steve99
Yes to be sure of any gain you would need to do before and after dyno runs
Its often jard to fine tuners who will use oft as most tuners want to lock tunes and oft doesnt lock tunes or lock ecu.
On an NA car with the mods oft tune is designed for ie headers and srock intake and if your on usa fuels any gains will be minimal
Old 08-21-2018, 06:57 PM   #11
NARFALICIOUS
Appreciate the response, Steve.
Though minimal, I would consider any gains. Do you think with a custom e-tune + intake + MAF rescaling, I could get at least 5 more WHP and an improvement over the curve on a before-pull?
Looking to see everyone's input on differences of:
Current Setup - UEL/Full exhaust, 93, stg 2+ v4.03
Add --> Intake+E-Tune
Then Add --> E-85+E-Tune
(i'm guessing with the service, they could make a gas & E85 version for my setup, if anyone can confirm?)
Thank you,
NARFALICIOUS
Noob Poster
1988 | 2016
Old 08-21-2018, 08:48 PM   #12
86TOYO2k17
Drives: 2017 toyota 86
Thank you,
I just got done with my e-tune last week. Took 6months, 1month per revision as it took 6 revisions to dial in my setup. although currently been using revision 5 as my IAM was constantly dropping. At 1IAM it pulled slightly harder but always dropped to about .9 making it pull less then 5th revision at 1IAM. But they said they where done making changes and I could use either revision. When it cools down I may try revision 6 again.
Mods effecting tune are grimmspeed intake, BPB, ace 250, hks double res fp, CSG mxp catback. Car daily drives way better and pulls way harder huge noticeable difference. Still some things here and there I feel could be improved especially for DD. Do to that, lack of customer support when I tried contacting/asking questions, and it taking 6months. Wish I would have just ecutek at a tuning shop, or maybe a custom DT tune.
Old 08-21-2018, 10:25 PM   #13
steve99
Thank you,
Ay gain will depend on how far "off" the current tune is. OFT basectunes were developed on uel header and your using uel.
You using good 93 fuel its likey knock correction will be small
So its just going to depend on how far fueling is off due intake or car variances
Its difficult to say but 5-10 hp is not out of the question if for example you were running way eicher than commanded afr
Old 04-17-2021, 07:46 PM   #14
Jasper
Jasper's Avatar
Drives: 2023 GR86
Um. It took you 6 months to get an E-Tune from OFT? Wow. Lol. That's absolutely terrible service.
Jasper is offline   Reply With Quote
The Following User Says Thank You to Jasper For This Useful Post:
Teseo (09-01-2021)
Is DD with a UEL and tune worth the jump to STX from DS imnotsureaboutbrz Tracking / Autocross / HPDE / Drifting 23 03-13-2017 06:39 PM
Tune + Headers +e85 Worth it? or wait for FI? brzfl Engine, Exhaust, Transmission 39 08-29-2016 08:55 AM
- 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune aaronsadventures Member's Car Journals 6 12-04-2014 02:01 AM
Bolt ons without a tune - worth it? Njjawn BRZ First-Gen (2012+) — General Topics 15 07-28-2014 10:42 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
