Old 08-08-2017, 11:19 PM   #1
Twitchy313
Twitchy313's Avatar
Drives: 2014 Scion FR-S
Oil change on the 86
What is the ideal time and mileage to change your oil on the 86??
Twitchy313 is offline   Reply With Quote
Old 08-08-2017, 11:26 PM   #2
ZX88
ZX88's Avatar
Drives: 22 BRZ
every 7500
ZX88 is offline   Reply With Quote
The Following User Says Thank You to ZX88 For This Useful Post:
Twitchy313 (08-09-2017)
Old 08-08-2017, 11:27 PM   #3
mmcelroy
Drives: FRS-ULTRA(lol)marine
usually between 930am and 1100am, or after 4pm if its summer; avoiding heatstroke is important! Closer to the middle of the day if winter.
Service manual I believe says between 5k and 7500 intervals. I don't have a copy of the manual on quick access... (doh)
mmcelroy is offline   Reply With Quote
The Following 5 Users Say Thank You to mmcelroy For This Useful Post:
Crashdummy (08-09-2017), MJones_RB (08-10-2017), pushrod (08-10-2017), Twitchy313 (08-09-2017), _sams86_ (08-09-2017)
Old 08-08-2017, 11:51 PM   #4
Impureclient
Drives: 2015 FR-S
Does anybody's car have a cricket sound coming from the engine bay?
Impureclient is offline   Reply With Quote
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
e_lunatic (08-09-2017), pushrod (08-10-2017)
Old 08-09-2017, 12:03 AM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
But how much oil to use? And what weight? I'm so confused.
Originally Posted by humfrz
I'm old and lazy
Old 08-09-2017, 12:10 AM   #6
arxm
Drives: 2013 FR-S, 2023 BRZ
not sure if sarcasm or not but you guys do realize we have user manuals in the car right? or like...google????
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
The Following User Says Thank You to arxm For This Useful Post:
Tcoat (08-09-2017)
Old 08-09-2017, 12:29 AM   #7
Twitchy313
Twitchy313's Avatar
Just getting others opinions, and some things on google are just bad advice, hence that's why we have these forums.
The Following User Says Thank You to Twitchy313 For This Useful Post:
Old 08-09-2017, 12:30 AM   #8
Twitchy313
Twitchy313's Avatar
Sorry, I meant how many miles should I go before I need to change the oil.
Old 08-09-2017, 12:57 AM   #9
Zentec
Drives: 2017 Toyota 86
If you have your Toyota Care every 7.5months or 7,500 miles that is what is recommend in your manual. If your Toyota care has ended then same. You can use the same Toyota oil filter but I recommend a good synthetic oil if you don't have an oil cooler use a 0w30 instead of the 0w20(Toyota and Subaru only recommends this for good gas mileage.) The 0w30 will give you better protection. In fact Subaru recommends this in Japan that's what it is designed for. If you track your car they recommend castrol stx professional 5w40. Or you can do it your self vary easy oil change on these cars.
But for every day driving put in 0w30 or get an oil cooler or both, brand is up to you royal purple, castrol, mobil 1, redline, ect. Toyota uses mobil 1 at the dealer.
Zentec is offline   Reply With Quote
The Following 2 Users Say Thank You to Zentec For This Useful Post:
e_lunatic (08-09-2017), Twitchy313 (08-09-2017)
Old 08-09-2017, 12:58 AM   #10
strat61caster
strat61caster's Avatar
There's nothing wrong with the manual suggestion of 7,500 miles between oil changes.
http://www.ft86club.com/forums/forumdisplay.php?f=41
ineedyourdiddly
Old 08-09-2017, 01:24 AM   #11
Twitchy313
Twitchy313's Avatar
I bought the car used and don't have the manual, so that's why I'm asking, but thank you for that, I appreciate it.
Old 08-09-2017, 01:38 AM   #12
Zentec
How many miles on ur frs?
Old 08-09-2017, 01:39 AM   #13
Twitchy313
Twitchy313's Avatar
Now 48,000, I bought it with 43,000.
Old 08-09-2017, 01:39 AM   #14
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Download all the owner's manuals for free!
https://www.toyota.com/owners/resour...uals/fr-s/2014
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
The Following 3 Users Say Thank You to NARFALICIOUS For This Useful Post:
strat61caster (08-09-2017), Tcoat (08-09-2017), Twitchy313 (08-09-2017)
Do it yourself oil change Wilso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 27 06-20-2016 02:11 AM
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 08:27 PM
Oil change stiboy808 Hawaii 6 05-25-2014 04:49 PM
When will you be doing your first oil change? pr086 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 40 12-10-2012 05:48 PM
Took my car in for an oil change... joshua BRZ First-Gen (2012+) — General Topics 25 08-04-2012 10:32 PM
