Old 08-04-2017, 07:26 PM   #1
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Installing 2016 Motor in 2013 Car
Is there anything ECU wise that I need to do, if I install a 2016 engine in a 2013 car? Is there anything outside of that?
Thanks for the help.
Installed Mods:
Old 08-04-2017, 09:27 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
No.
The Following 2 Users Say Thank You to Wayno For This Useful Post:
Sojhinn (08-04-2017), Teseo (08-04-2017)
Old 08-04-2017, 09:44 PM   #3
Sojhinn
Sojhinn's Avatar
Originally Posted by Wayno View Post
No.
Simple and direct. Thank you!
Installed Mods:
Old 08-04-2017, 11:18 PM   #4
pinetree
pinetree's Avatar
Drives: 2013 BRZ Limited
What about 2017 engine? Just curious if easy swap or not worth the hassle.
pinetree is offline   Reply With Quote
Old 08-05-2017, 12:14 AM   #5
Sojhinn
Sojhinn's Avatar
No.
BTW- When you say no.. you mean there won't be issues. Or no dont do it.
Installed Mods:
Old 08-05-2017, 02:19 AM   #6
steve99
2016 should work, just change the motor leave the engine ecu alone
Re putting a 2017 motor in again should work (no guarantee) dont change the ECU that will 100% not work with the 2017 ecu programming in the older cars. Use the current cars ecu or at least the current cars ecu calibration id rom in ecu.
Old 08-05-2017, 03:09 AM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
There are changes to various sensors on the MY17 so it might not be p'n'p. Whether you can reuse older sensors is unknown at this point I guess. As for a MY15/16 I'm sure I've read there are sensor changes again that throw a CEL but reusing the ones from the original engine solves the issue.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Teseo (08-06-2017)
Old 08-05-2017, 08:08 PM   #8
Sojhinn
Sojhinn's Avatar
Do you remember which sensors?
Installed Mods:
Old 08-06-2017, 03:38 AM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'm afraid not. Cam sensors seem to come to mind but I'm not certain. I did try and have a search when I posted, it's from a post on here so maybe you'll have better luck.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-06-2017, 03:52 PM   #10
Sojhinn
Sojhinn's Avatar
Yup been trying to find it. But the cam sensors are not hard to swap at least.
Installed Mods:
Old 08-06-2017, 09:53 PM   #11
steve99
I know we can run the 2013 ecu firmware in any car from 2012-2016, and the ecu hardware is same from what ive seen and done a few ecu swaps now from cars in different countries.
This would seem to suggest that the input and output signals to the ecu are same.
however i do seem to remember their might be some changes to the physical plug/loom might have been cam sensors or ignition coil packs but just guessing.
I have not done motor swaps just ECU swaps from various cars.
Old 08-06-2017, 09:54 PM   #12
Sojhinn
Sojhinn's Avatar
I'm going to make sure to document the changes so we all know.
Installed Mods:
The Following 3 Users Say Thank You to Sojhinn For This Useful Post:
JermMX5 (08-08-2017), steve99 (08-06-2017), strat61caster (08-11-2017)
Old 08-11-2017, 05:47 AM   #13
Sojhinn
Sojhinn's Avatar
It's alive! 2016 motor is in and it's currently running. Utilizing the MY16 wiring harness nothing was swapped from the old engine sensor wise.
Car fired right up and no lights. I get the car back tomorrow (tonight?) night.
So freaking excited.
Installed Mods:
The Following 6 Users Say Thank You to Sojhinn For This Useful Post:
Chronology (08-11-2017), funwheeldrive (08-11-2017), My Key (08-11-2017), steve99 (08-11-2017), strat61caster (08-11-2017), Tcoat (08-11-2017)
Old 08-11-2017, 10:57 AM   #14
Chronology
Drives: 13' Satin White Pearl BRZ
Get some sleep man, you have a long drive coming up! Glad it worked out. Just remember that clutch is going to be breaking in for a bit.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
The Following User Says Thank You to Chronology For This Useful Post:
Sojhinn (08-11-2017)
Need help installing subwoofer with amp to oem HU and sound system (2016 FRS) Sonicp9 Electronics | Audio | NAV | Infotainment 15 08-12-2022 10:40 PM
2016 Motor Trend Best Driver's Car TylerLieberman Other Vehicles & General Automotive Discussions 32 09-27-2016 01:23 PM
Geneva Motor Show 2016 JPxM0Dz Other Vehicles & General Automotive Discussions 0 03-03-2016 04:06 PM
Motor Trend 2016 Hyperblue long term test Speed2th BRZ First-Gen (2012+) — General Topics 21 01-02-2016 12:41 PM
Motor Trend: 2016 Miata vs 2015 BRZ Entroper FR-S / BRZ vs.... 753 11-19-2015 01:52 PM
