Good Job Subaru!
Drives: '18 440i GC, '24 CX-50 Meridian
Invidia N400 Exhaust Rattle
Hey everyone,
I installed my Invidia R400 just over a month ago and have been loving it so far. However, after just over a month of having it installed, I've noticed for the first time today that there is a noticeable metallic rattle coming from what sounds like the rear of the vehicle in certain conditions (under reasonably light to full heavy acceleration load, around 3200-3500 rpms and again around 4000 rpms; then on coast at similar rpms as well as 2200ish rpm). I got under it and tightened what I could without lifting the car (tightened the midpipe to catback connection, I'll be lifting the car up tomorrow after work), but to no avail. If I played with the exhaust in the rear then start driving the noise goes away for a few minutes before starting up again. An audio clip here, to be more specific (pay attention ~0:10 for the metallic noise): [ame="https://www.youtube.com/watch?v=DRa-8veLKN8"]BRZ Exhaust Rattle - YouTube[/ame] Any thoughts?
Drives: Red Brz
Did you check the whole exhaust to see if it's touching something or about too?
#3 | |
Drives: FRS, Supra, Colorado D, GLC63
Good Job Subaru!
![]() Found the culprit. The weld on the hanger bracket between the rear section of the pipe and the primary hanger is weaksauce. Not sure if there's a point warrantying it if the welds are so weak from the factory. I'll head to the muffler shop next week to fix this with a nice fat weld, as well as the other side to prevent that one from breaking as well. For now, a temp solution to cure my annoyance: ![]()
The Gunshine State
Drives: '14 BRZ Limited
Lol nice temp fix.
![]() Current DD: M235i |
Spun
Drives: 23' Supra
Good find. That will do it! I would try muffler cement or get it over to a local
Shop. Quick weld and you'll be all set. Send the bill to Invidia. |
Drives: '15 BRZ
I had this as well and my diagnosis was something inside the pipe, I'll have to check my hanger brackets to see if they're broken
Instagram: jimmyjimmyjimmy_
Good Job Subaru!
![]() Finally went to the exhaust shop on my lunch break today to get the brackets rewelded. No issues now!
#9 | |
Drives: 15 BRZ LTD, 05 FXT
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#10 |
Drives: 2019 BRZ PP
How much did it cost to reweld? This noise is coming from mine too
#11 |
Drives: '14
| Invidia N1 Silencer rattle | halo13 | Engine, Exhaust, Transmission | 6 | 01-16-2020 01:56 AM |
| Exhaust rattle. | mattaubel | Engine, Exhaust, Transmission | 1 | 07-26-2016 01:52 AM |
| FS: Invidia Catless Front Pipe/ Invidia Q300 Exhaust Parts | timmydatooth | Engine, Exhaust, Bolt-Ons | 27 | 04-04-2016 09:46 AM |
| Aston n400 v8 | ort895 | Engine Swaps | 0 | 11-08-2015 11:50 PM |
| Tip-in knock or exhaust rattle? | solidONE | Software Tuning | 16 | 09-25-2015 12:19 AM |
