Old 02-06-2016, 09:19 AM   #1
halo13
Invidia N1 Silencer rattle
I just installed an invidia n1 exhaust last night and all went well. Without the silencers it's pretty darn loud and the in-car drone is too much. So this morning I put the silencers in and locked them down tight. It totally tamed the exhaust down and shouldn't wake up the neighbors or attract cops.
My question is, at idle on cold start the silencers vibrate a bit which sounds crummy. The silencers are held on by one screw/nut. What can I do to make sure they fit better? There's a .5mm gap in between the silencer and the tips. Can I wrap it in heat wrap or something for a snugger fit?
Advice greatly appreciated.
halo13 is offline   Reply With Quote
Old 02-06-2016, 02:21 PM   #2
humfrz
Redneck fix ........ jam a piece of shingle in there.........
humfrz
Old 02-07-2016, 06:11 AM   #3
ShackontheTarget
ShackontheTarget's Avatar
Drives: GT86 Aero
I had the same issue with the N1 silencers, then I stopped using them. They'd also cause a weird whistling sound when air escapes in the gap between their edge and the exhaust tip. After about 1000 miles the exhaust will quiet down and the drone will be much much less, you'll start enjoying it.
ShackontheTarget is offline   Reply With Quote
Old 02-07-2016, 09:26 AM   #4
halo13
I guess in the meantime I'll leave the silencers in while the exhaust builds up carbon. Without the silencers the in-car drone is insane and I can't hear myself think. Outside the car it's not as loud but it does set off sensitive car alarms. Trying to keep the Po Po from pulling me over for a loud exhaust. This is Texas, but still there are some not so cool cops.
Old 02-07-2016, 10:05 AM   #5
FRS Justin
Drives: 2013 Asphalt FRS
2 choices on how to fix it.
1 You can take a sharpie and mark where the metal lip sits in the muffler. Remove the insert and apply high heat RTV inside of line and re install insert so the rtv is pushing against the insert. Clean the surfaces well
2 spread the flange on the insert and re install so its a tight fit. This will take a little time to get it right but works as well as fix1. Be sure to remove any burrs on insert so you don't scratch your muffler. good luck
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 02-07-2016, 10:07 AM   #6
halo13
Both are really good ideas. I think spreading the flange would be the best option. Sounds like the RTV might get messy and not sure if it will hold up against the exhaust temps but I may try it too
Hopefully I can get rid of the silencers when this thing quiets down.
Old 01-16-2020, 01:56 AM   #7
86driftcar
86driftcar's Avatar
Appologies for resurecting a 4 year old post but I too have an Invidia N1 which was super loud until I put the silencers on.
I no longer wake up the neighbours and set off car alarms but the rattle is brutal, I'd say I'm almost better off without them now. My Invidia N1 sounds like a no name brand ebay exhaust and rattles intensely.
Just to put things into perspective, I have a supercharger installed. Aside from the suggestions above, I was thinking of bringing it to a muffler shop and have them weld the silencers straight onto the exhaust. What do yall think of this?
86driftcar is offline   Reply With Quote
**INVIDIA** >>SUPER SALE THREAD<< - Invidia N1 - Invidia Q300 - Invidia Front Pipes - FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 629 12-11-2016 09:21 PM
WTB>FRS invidia n1 silencer FR-Sky Want-To-Buy Requests 0 02-02-2016 02:06 AM
tomei 60s / 60r silencer Carolinabuiltbrz Engine, Exhaust, Bolt-Ons 0 10-22-2015 02:57 PM
Invidia N1 Exhaust Silencer vs. No Silencer Comparison Teeeg28 Engine, Exhaust, Transmission 3 06-20-2014 01:04 PM
Invidia N1 Exhaust Silencer vs. No Silencer Comparison Teeeg28 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 06-19-2014 05:46 PM
