Old 07-31-2017, 02:59 PM   #1
imnotsureaboutbrz
Drives: between cars...
Question about Rev limiters: stock vs 'tuned'
My BRZ is currently stock, and there have been a couple of occasions during some autocrosses where I want/need to hold the car at the rev limiter. My past cars would just bounce off of the limiter until I was off throttle. but with the BRZ it hits the limiter and dies off, I'm not sure if its a fuel cut or ignition cut but it's a trait I would like to get rid of if I move into STX.
So to those who are more knowledgeable than me... When you tune the 86 either OTF or ECUtek does the car still act the same at the rev limiter?
imnotsureaboutbrz is offline   Reply With Quote
Old 07-31-2017, 03:31 PM   #2
steve99
most tuners will program in a "soft" rev limiter rarther than the hard fuel cut of the stock rev limiter.
The stock fuel cut rev limiter has a large hysteresis about 300 rpm ie if you hit 7400 fuel is cut till you go below 7100
Example below rev limit is increased to 7600 ( this is not necessary) bit the stock hysterysis is reduced to 50 rpm from 300 and also ignition retard is used initially to dull the power before you hit the fuel cut. This produces a soft limiter that you can "hang" at the limit rarther than die or bounce off it.
Stock, tuned with Ecutek 19eightysix Software Tuning 10 03-23-2015 12:46 PM
Kraftwerks C38 Kit IN STOCK! Installed & tuned special! Xero-Limit Forced Induction 19 11-20-2014 06:51 AM
Circuit Motorsports Tuned Stock BRZ: +17whp & +12wtq Circuit Motorsports Software Tuning 112 02-20-2014 01:13 AM
What tunes can be reflashed to stock and then back to tuned ? ScionFR-S Software Tuning 11 11-21-2013 02:50 AM
Got my stock BRZ tuned at Drift Office over the weekend... edocura Engine, Exhaust, Transmission 46 05-23-2013 08:05 AM
