Old 07-26-2017, 10:10 PM   #1
James Russels
Drives: 2013 FRS
Quoted $750 for a paint chip repair - Need advice
Hi everyone,
Pictures: http://imgur.com/a/rLmoN
I recently found a rusting paint chip where the roof of the car meets the windshield. The body shop I contacted quoted me between $650 and $750 because it would require removal of the windshield.
Does anyone have experience with DIY rust/chip repair? My understanding is it would be sanded down until there is no more rust, coated with a sealant, then painted over. I don't mind if it doesn't look perfect, I really just want to stop the rusting and not pay hundreds of dollars.
Really appreciate any feedback, thanks.
James Russels is offline   Reply With Quote
Old 07-26-2017, 10:15 PM   #2
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Find a different place first? Go ask around
Old 07-26-2017, 10:19 PM   #3
James Russels
Drives: 2013 FRS
I've had work like this done twice before, and they were both bad experiences. I'd like to see if DIY is feasible.
Old 07-26-2017, 10:23 PM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
Ignore it. You'll get plenty more. Fixing every one of them will be just silly financially.
If you're serious about it, repair this one and clear bra the leading edge.
Old 07-26-2017, 10:29 PM   #5
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
I have the exact same chip in the exact same place, mine's not rusting yet though.
You could hit it with a fiberglass sanding pen and some Dr. Colorchip...fairly cheap. I'm not up on what, if anything, to seal with.
https://www.amazon.com/gp/product/B000FN8H52/
BRZyJ is offline   Reply With Quote
Old 07-26-2017, 11:05 PM   #6
James Russels
Drives: 2013 FRS
I'm fine with spending $50/year to fix these. But again, if I can learn to do it myself, it'll obviously be a lot less expensive.
Thanks for the input - will probably get both of those once I have everything planned. Unfortunately, the part I'm also most uncertain about is the sealant.
Is anyone familiar with what would be used to seal the bare metal after the rust is removed?
Old 07-26-2017, 11:46 PM   #7
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
I had some deep chips that I filled up with some Dr. Colorchip. The paint match is pretty great, and I managed to use it for a lot more than they promise.
carsebuco is offline   Reply With Quote
Old 07-27-2017, 12:10 AM   #8
BRZyJ
BRZyJ's Avatar
I just looked at my Dr. Colorchip stuff, it comes with a bottle of blending solution called "SealAct" that they claim "serves a dual purpose of both blending away the excess paint and sealing the repaired chip".
I've only done a few small chips/scratches...like carsebuco said the color match (mine's silver) is pretty much right on. Some chips will take some experimenting and several applications to get it level.
Old 07-27-2017, 09:58 AM   #9
bass_114
bass_114's Avatar
Drives: wrb brz
I had this done on my previous Subaru legacy, the windshield had been replaced in the past and was not sealed good so all around the contour was rusted or bubbling. had to remove the windshield grind all around and paint, I opted to paint until half the roof though and blend. Cost was 600 cash Canadian at a legit body shop.
bass_114 is offline   Reply With Quote
Old 07-27-2017, 02:08 PM   #10
strat61caster
strat61caster's Avatar
Manufacturers make paint pens to match instead of hitting up aftermarket, although I don't know much so maybe the manufacturers are just relabeling the aftermarket ones.
https://www.amazon.com/Genuine-Subar...pearl+touch+up
Haven't done it myself but it's on my to-do list as the roof has paint flake off on me.
ineedyourdiddly
Pat (07-27-2017)
Old 07-27-2017, 03:30 PM   #11
Pat
Pat's Avatar
Drives: 2023 BRZ
Thanks, strat61caster. I just ordered one.
Old 07-28-2017, 08:23 PM   #12
Sbk Brz 17
Drives: '17 BRZ Series.Yellow;'07 2500HD
I have a spot sand blaster by "Vacula" purchased many years ago from the Snap-on tool truck. It is a hand held pneumatic sandblaster which uses various tips and a thick rubber template mat to blast a spot down to bare metal--spots down to the size of a BB. Leaves a sharp edge to the clean area which makes filling it with primer and color a snap(use a toothpick on small areas to apply paint). The results are great, of course depends on the color-match of the touch-up paint.
Sbk Brz 17 is offline   Reply With Quote
Old 08-01-2017, 12:55 PM   #13
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
i have a few paintchips as well with rust and got a paint pen. i dont wanna spend thousands of dollars obviously so my plan is so scrape the rust and sand the chip a couple MM larger then just paint pen over it and hope it works lol
ImAdopted is offline   Reply With Quote
Old 08-01-2017, 08:27 PM   #14
stevesnj
stevesnj's Avatar
I use this paint site, perfect matching and they have paint pen Primer, Basecoat, Clearcoat and vids to help out. Should get good results if you follow the process.
http://www.automotivetouchup.com/
My 2016 Build thread
Rock Chip Repair Recommendations Wyattkb Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 24 03-21-2016 11:39 AM
Big paint chip, is touch up paint sufficient enough? simplydang Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 03-02-2015 04:41 PM
Paint chip repair fatalelement Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 12-16-2014 03:20 PM
Guys i dont know if its clear coat chip or paint chip.. HELP BRZ_Kamil Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 05-19-2014 10:23 PM
First Paint Chip - Opinions on cost and/or difficulty of repair whataboutbob Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 09-27-2012 11:36 AM
