Old 07-20-2017, 10:59 PM   #1
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Track Suspension
Shop is asking me for specs for when they do my suspension. I want a track only set up the car is not my daily. Suspension going on is coilovers, adjustable rear lca, adjustable rear toe rods. So what camber/toe/caster you guys running at the track?
tofurun is offline   Reply With Quote
Old 07-21-2017, 03:29 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
What tyres are you using? What are your spring rates?
Old 07-21-2017, 10:43 AM   #3
Icecreamtruk
Drives: Track preped NA FRS
You main concern should be what tire and size you will be running (camber settings is also depending on tire size, wider tires require less camber). After you have selected a tire, you need your spring rates to be able to handle your tires and your aero. After you have tires and springs, then you can go to tweat the alignment, and you can have a starting point, but only track data will really tell what your settings should be (tire temp and wear accros the patch, as well as focusing on either tire life or maximum grip at the expense of life).
My quick and dirty setup for my track daily car on RS4 tires and basic aero (wing, splitter, hood vents, skirts and diffuser) is: 6kg/8kg springs, -3.8F/-3.2R camber, -0.1 toe-out front, 0 toe rear, ride height 1.5" lower in front, 1" in the back. It works very well, car is balanced with shocks softer on the front, but can be moved towards oversteer or understeer with shock adjustments only. Stock sway bars.
The Following User Says Thank You to Icecreamtruk For This Useful Post:
wparsons (07-25-2017)
Ultimate DD/Track Suspension stoked_on_spool Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 10-14-2015 10:28 PM
Dedicated Track/Race Suspension Iwannajag Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-05-2015 03:47 PM
Track Suspension Settings Jonsey Tracking / Autocross / HPDE / Drifting 7 02-08-2015 11:55 PM
Track suspension advice ddeflyer Tracking / Autocross / HPDE / Drifting 138 05-29-2014 06:35 PM
Suspension for Auto-X v. Track.... How different? mtimney Tracking / Autocross / HPDE / Drifting 3 08-20-2013 02:18 PM
