Old 07-20-2017, 08:10 AM   #1
tanner
Drives: '10 S4/'13 BRZ/'16 GT4/E30 M3
Clutch pedal - "squishy/squeeky" sound?
Noticed that this started to happen this past weekend, anybody else have this? Only have about 35,000 km on it but a lot of track time. My other car (Audi S4) has the same issue and ended up trying to spray some lithium grease where the plunger which helps but only comes back later, have not done this yet on the BRZ. I known hot weather is a factor with the S4, though the BRZ was parked underground when it started to do this.
Mike
tanner is offline   Reply With Quote
Old 07-20-2017, 09:37 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Unless it's something really loud that really gets on nerves a lot .. i'd probably wouldn't care. Unlike audi S4, which is more upmarket with more luxurious interior & better noise insulation .. there are many rattles/noises in my twin that i ignore "because [cheap] racecar"
Old 07-20-2017, 09:39 AM   #3
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Does it happen when the pedal is pushed almost to the floor? Mine has been doing that, but it sounds like the squeak is coming from inside the bell housing. Luckily I can't hear it when the car is actually running.
smg1138 is offline   Reply With Quote
Old 07-20-2017, 09:49 AM   #4
tanner
Yeah just wanted to check to see if there was some sort of sign of impending doom for the master cylinder but was thinking probably not. There's so much road/engine noise in the BRZ I didn't notice it until I was a stop and had the radio turned off.
The squishy sound happens when the clutch pedal is being depressed, hence guessing it was the same thing I'm having with the S4. Which by the way, I rather drive the BRZ than the S4.... BRZ is a lot more fun, S4 I keep complaining about how heavy it feels, so the S4 pretty well sits in the garage all summer long.
Mike
Old 07-20-2017, 09:59 AM   #5
Moue
Drives: 2014 Lightning Red Subaru BRZ
Could be the clutch pedal assembly. I had a clicking sound when fully depressing the clutch pedal. If you still have the 3 year warranty they'll replace it with no hassle. Do you feel any "vibrations" when fully depressing the clutch pedal?
Moue is offline   Reply With Quote
Old 07-20-2017, 10:05 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Oh, well, if it is something like master clutch cylinder and so on i WOULD care .
But from OP & thread name i got impression that it's just pedal assembly, that's noisy. If tolerable, not too annoying, just let it be . More redlining, louder music should do.
With pedal i got noise i couldn't tolerate, when i tried pedal dead travel adjustment mod, stock clutch bum stop was quickly cut through, resulting in loud metallic clunk i couldn't live with. But slight squeek at top of depressed travel .. i have it too, and don't even notice due being used to. I'm more minding clutch steady engagement/rpms/grip in curves for gearswitch/handling/braking points, then interior noises. And if anything, things like rear seat latches rattle from noises are more annoying then that of clutch pedal's
Old 07-20-2017, 10:24 AM   #7
tanner
Not that I'm aware of, but guessing if I do that could be the throwout bearing on it's way out.
Mike
Old 07-20-2017, 11:32 AM   #8
humfrz
Originally Posted by tanner View Post
Noticed that this started to happen this past weekend, anybody else have this? .
Oh, ........tanner .........
I don't do this much but, ........
Maybe ol @Tcoat will come along and give you a few dozen references.
Maybe @Ultramaroon will come along and learn ya how to grease up some clutch parts.
Meanwhile, relax, the car will be OK to drive ......
humfrz
Old 07-20-2017, 11:39 AM   #9
tanner
Yes, should have mentioned, I did try and search but guess the key words i used such as squeek and squishy didn't come up with anything. thx anyways.
Mike
Old 07-20-2017, 12:32 PM   #10
humfrz
Well, OK ...... hint: I suggest you use Google to search .....
(it also helps to spell "squeak" correctly ..... )
First off, I would suggest you check the master cylinder to make sure it's full of fluid.
Then, you may wish to follow this mini DIY from @Ultramaroon :
Quick & dirty:
1. Detach the slave cylinder. Leave the hydraulics alone.
2. Remove the dust boot from the fork.
3. Reach down behind the fork with a finger and feel for the pivot. It's going to be tight because of the retaining clip.
4. Squeeze a decent glob of Lucas Red & Tacky #2 in there with your finger.
5. Jiggle the fork to distribute the grease as much as possible. It'll work in more on its own.
6. Put a dab of grease in the top pivot where the slave pin goes.
7. Reassemble.
That outta get ya started.
If all that don't shut it up, you could bleed the clutch hydraulic system.
humfrz
Old 07-20-2017, 12:53 PM   #11
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
It depends how bad the squeak is. I actually noticed the same thing on my frs around the same mileage, but it was a minor thing so I ignored it. I'm at 67k now and I barely notice at all anymore. I just flushed my clutch fluid and I swear it's gone now maybe I'm used to it but if it doesn't affect the clutch function at all and just a slight squeak it may go away on its own with time like it did with me.
DandoX is offline   Reply With Quote
Old 07-25-2017, 12:30 PM   #12
Darkrune
Darkrune's Avatar
Drives: 2017 86
Hmfrs said it, but I was going to suggest bleeding, then add a little fluid. Prime the clutch, bleed and then check fluid level.
Sent from my SM-G935V using Tapatalk
Darkrune is offline   Reply With Quote
Old 07-25-2017, 01:14 PM   #13
funwheeldrive
Check out this thread
http://www.ft86club.com/forums/showthread.php?t=117440
Old 07-25-2017, 01:36 PM   #14
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Mine did that for a while then goes away after i change the way i hold/let go of my clutch * I forget what i did exactly.
I know.... our car is weird....... i have a new noise every 10k mile and they are switching around in the car. Newest one is near the rear glass.....
Who's tired of the "Pedal Dance" and wants to be in real control of their car? FT-86 SpeedFactory Tracking / Autocross / HPDE / Drifting 61 10-01-2015 07:44 PM
Clutch pedal springy sound pdreams Issues | Warranty | Recalls / TSB 16 06-01-2015 02:33 PM
Just changed pads and fluid; brake pedal has more "dead space" ryoma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-13-2015 02:56 AM
REQ: Looking for sound clip of Nameless 2.5" "No Muffler" Dual Exhaust Axleback jbsali Engine, Exhaust, Transmission 1 01-28-2014 07:22 AM
Additional "pedal dance" testing. CSG Mike Tracking / Autocross / HPDE / Drifting 55 08-27-2013 03:02 AM
