Old 07-19-2017, 01:16 PM   #1
allowe
allowe's Avatar
Spc front camber bolts benefits
Are there any significant benefits to using those on stock suspension?
allowe is offline   Reply With Quote
Old 07-19-2017, 01:35 PM   #2
strat61caster
strat61caster's Avatar
Yes. The suspension design means that the car requires a rather significant amount of static camber up front to give you maximum grip during cornering. Camber bolts (on this car) give you a modest increase in static camber which should have noticeable improvements in cornering grip on the front end with almost no downsides for minimal cost.
However if you've never thought to yourself "man I wish I had a bit more cornering grip" and think you never will then it will likely feel like money wasted.
Additional camber up front is required for any competitively autocrossing 86, especially the ones on stock suspension.
ineedyourdiddly
Racecomp Engineering (07-19-2017)
Old 07-19-2017, 01:41 PM   #3
allowe
allowe's Avatar
Haha actually I've always thought my car has no grip! On back roads it's amazing but I still slide around everywhere. I'm getting good tires soon but I was just wondering if adding these will make a difference. They're really cheap so it doesn't hurt to have them. I'm currently happy with the stock suspension and I don't want to lower it as I daily my car and pretty much plow through potholes rather than avoid them.
Oh do they wear out tires faster ? / any negatives?
Also, do I need just those bolts or are there other bolts that I need?
Anyways thanks for your reply!!
Old 07-19-2017, 01:48 PM   #4
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Don't forget to get your car realigned after installation.
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
allowe (07-19-2017)
Old 07-19-2017, 01:49 PM   #5
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Install the camber bolts, get your car aligned, and go have fun!
asdf is offline   Reply With Quote
The Following 2 Users Say Thank You to asdf For This Useful Post:
allowe (07-19-2017), Azzudien (07-19-2017)
Old 07-19-2017, 02:10 PM   #6
allowe
allowe's Avatar
You only need 1 set though right ? Do I need other bolts? I'm reading up about a crush bolt or something like that
Old 07-19-2017, 02:19 PM   #7
asdf
asdf's Avatar
Drives: #0517
Only need the one set and you are good to go.
Old 07-19-2017, 04:19 PM   #8
strat61caster
You have a few options on that front actually.
http://www.ft86club.com/forums/showthread.php?t=103609
ineedyourdiddly
Old 07-19-2017, 04:20 PM   #9
allowe
allowe's Avatar
Do they have any negative consequences in using them tho? Like tire wear Etc
Old 07-19-2017, 04:32 PM   #10
strat61caster
Read the link I posted.
Or I feel like I'm in the mood to procrastinate and spoon feed people so here it goes.
General consensus is that if you do a lot of freeway driving or like most people who daily their car 90% of it is on public roads never approaching the limits of traction that increasing camber much past -2.0 degrees will create noticeable inner shoulder wear. It may be noticeable even completely stock that the minimal camber already part of the car wears out the inner shoulder of the tire first. But if it's a weekend car that sees mostly hard driving you will actually improve tire wear as stock geometry will wear the outer shoulder of the tire.
You won't get that much camber with just bolts imo, but it's why I prefaced my suggestion about the car being driven hard. We're not talking about 'oh my tires only last 6 months now' we're talking about like a 5% or 10% decrease in tire life with reasonable amounts of camber (<-2.0).
ineedyourdiddly
lazyluka (07-19-2017)
Old 07-19-2017, 04:35 PM   #11
lazyluka
Drives: GT86
Almost no negative consequences, just get your wheel alignment to set you up with 0 toe up front. Rear can be 0 toe as well, but you may wish a tiny bit of toe in for stability.
Toe is the big tire killer if it's too far away from 0.
Oh, with the camber bolts, make sure you install them and set them for max camber, this is the safest and best way to set them up. You don't need to worry about fine tuning it for camber to be perfectly equal on both sides.
lazyluka is offline   Reply With Quote
Old 07-19-2017, 04:39 PM   #12
allowe
allowe's Avatar
Can't it be done without an alignment then? Basically seeing where it maxes out and tightening ? I did an alignment not too long ago
Old 07-19-2017, 04:42 PM   #13
lazyluka
Drives: GT86
Adding the camber will affect your front toe, so no I wouldn't do it without alignment.
Old 07-19-2017, 04:53 PM   #14
allowe
allowe's Avatar
Thank you for that ! And I don't touch the rear alignment right ?
OEM front camber bolts B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-30-2014 08:05 PM
WTB Front Camber bolts manualmotive Want-To-Buy Requests 2 04-17-2014 02:45 AM
Front Camber Bolts option hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-10-2013 12:28 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
